WTB: Spring tooth harrow parts
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: WTB: Spring tooth harrow parts
    Posted: 11 May 2016 at 8:55pm
I have a spring tooth harrow that is missing two front shanks. There are four shanks in the back row and three in the front. I need two of the front ones. I need the brackets with the two set screws that mount them as well.
http://simpletractors.com/attachments/harrow.htm
Thanks in advance.
Edited by littlemarv - 14 May 2016 at 2:54pm
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2016 at 9:01pm
If someone would be kind enough to post how to make that a live link, I promise I will print it out and tape it to my end table next to my chair so I can do it myself!
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 8:10am
Tri-State Show, Portland, IN,  May Swap-meet and August Show is a good place to find such items.  Actually, most any large show. Le Sueur, MN is probably much closer for you. And you may find at some small show with only a few old iron venders.   Suggest taking along a sample to insure you get the identical item. Happy hunting. Herb(GA)
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 12:34am
can you post a pic of what you need? I have a few old harrows here I can dismantle!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 4:47am
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 6:09am
Take the   www.  out of the link
Gary
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 1:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 10:29pm
Finally found the pictures- had to dig awhile.
Here is the harrow, you can see it only has one "front" shank.
I need two of these.
Thanks.
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 11:35pm
You only need one as it only supposed to have six springs on it. That will be a very hard part to find as these harrows are very rare.
AC part numbers needed =
72026899 Standard
72026901 Spring
72025769 Clamp
72025756 Nut -special (available at The Parts Depot in WI)
72026900 Bolt -special (qty 2 req.)
Here is a link to the parts manual with Simplicity part numbers.
http://bsintek.basco.com/BriggsDocumentDisplay/heCBEN8aqNZrE3Cvh5kbp796Dq.pdf
I think your best shot would be finding another incomplete one and making two, or maybe some of these parts are laying on an old dealer's shelf somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2016 at 12:06am
All the ones I have ever seen have 7 shanks. Like in the link above.
I was hoping to find someone that has a partial one laying around...
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2016 at 6:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2016 at 5:23pm
Parts book is wrong, my bad.
Should have known better as I have one of these harrows out back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2016 at 10:32pm
So the spring teeth are all the same, its brackets #13 and #16 that make the difference.
Any any rate, I still need two whole assemblies for the front row of tines....
Are these really that rare? I sure like the way it works the ground up, I'd just like to get it back to original....
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2016 at 10:19pm
i'll look see what mine look like
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 7:45pm
I have the parts you need if you Havnt found them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2016 at 10:42pm
I would like to find a harrow like that
