Allis Chalmers 5020 Electric Pto belt tension
Jcutler81 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 5020 Electric Pto belt tension
    Posted: 08 May 2016 at 12:55pm
Hello, hopefully someone can help me. I have an Allis Chalmers 5020 with a belly mower 60 in. I bought it at an estate sale. It mows in very short grass, the electric pto clutch seems good, but the belt never seems to fully tension tight. One of the lower pullies where it shows the tension can be lifted up and down while the belt is on.
I am pretty sure the issue has to do with the two lower pullies that handle the tension. I have replaced the belt and it does the same thing.
Whenever I hit even remotely tall grass, the belt start wobbling and sliding around the pulley on the mow deck.
Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2016 at 2:35pm
It looks like the spring on the pulley may be gone. Does anyone know a part number or equivalent?
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2016 at 2:40pm
Don't know the number but I can get a picture of mine
Life is tough,but it's tougher when you're stupid. - John Wayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2016 at 3:05pm
Thanks, and if you have an idea of the length, that'd be great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2016 at 9:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2016 at 4:33pm
How'd you make out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2016 at 4:47pm
Thanks for taking the time to show me. It worked out! I had a spare spring that fit perfectly! Thanks for your help!
BrianC View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 7:19pm
That looks like a #71664661 to me, if remember correctly.
Let's check the  AGCO parts books online, login as guest, select ACGO Allis dropdown for the BRAND, type in 5020 for model.
Select 5015 / 5020 / FWA / 5030 ACCESSORIES AND IMPLEMENTS
Hum, very interesting look at all that stuff they made for the 5015, 5020, 5030.
Page 142 (
CENTER MOUNTED - DRIVE HITCH & LIFT ASY), there is
that spring (item 16) I remember.... is that the correct one?
What are the odds AGCO has it? When you strike out at the Allis parts guys, perhaps Massey Ferguson sold
the same machine, and try that path. When that fails you, look you have a scaled
photo given.
I just wanted to remind ya all that the 5020 is in the AGCO parts books online.
But they don't have the 620/720!
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 6:05pm
I have a copy of the 720 parts manual.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 8:59pm
I have another open thread. There is a little round rubber bumper that the mower deck bounces against. The rubber degraded and 90% of it came off somewhere in my field. No luck finding it, anyone know what that part would be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 11:49am
Does someone have a picture of the position of the belt guards on the pulleys below the electric Pto, I don't think one of mine is positioned properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 9:30pm
Not sure what you mean. The only belt guards on the machine are fastened to the mower deck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 9:34pm
The pulleys that you pictured above, do they not have a bar on then that secures over the belt? I'll try to get a pick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 9:44pm
There are 2 1/4" rods that hold the assembly on the tractor but not necessarily the belts
Edited by EricPA - 24 Jun 2016 at 9:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 10:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 10:09pm
These two L-shaped bars that cover the belt on the pulleys
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 10:21pm
Ok,mine does not have those and I have never had a problem with the belt coming off. Don't recall seeing them in the manual either
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 10:22pm
I'll need to check. Thanks for the extra set of eyes.
