WD - WD45 air cleaner question
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Topic: WD - WD45 air cleaner question
    Posted: 11 May 2010 at 1:50pm
I have a 1953 AC WD that I bought with a WD45 carburetor. I assume it also has a WD45 air cleaner because I think the WD air cleaner is smaller.
Well, the problem I have is that the air cleaner is resting against the exhaust manifold and previously burned a hole in the air cleaner shell.
What do you recommend to make it fit better?
I was thinking of slotting the bolt holes so the air cleaner can move further away, but I thought I'd ask you experts first. I'm sure someone has put a WD45 carb and air cleaner on a WD before and I'd like to find out what you did.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 6:17pm
An original WD45 manifold or most of the current universal replacement (WC,WD,WD45,early D17) manifolds work better than an original WC/WD manifold with the 45 air cleaner. You can carefully grind your manifold for clearance, it does not take very much, I've done that before. Kip
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 8:22pm
dont grind the manifold,you will create a hot spot.i have 6 wd-45 and had to relieve the holes on the cleaner mount bracket.dont take much
