Orange or yellow paint
Ferdinand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Topic: Orange or yellow paint
    Posted: 07 May 2016 at 11:27am
Just wondering about Orange or Yellow paint on AC dozers. Was the Orange phased out at some point or were the color choices an option.
For instance: AC Mel just brought home an HD19 thats orange. I've seen several HD19 on Craigslist, all are yellow. There is an HD11G for sale that's orange but, it might be a repaint.
If I paint a yellow AC dozer orange, do I get chastised from AC aficionados?
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 12:10pm
I was asking on this very subject here on the forum probably 2-3 years ago, you might be able to pull up the thread with a search. What seemed to come as an answer was that dozers and other equipment sold through farm equipment dealerships came as orange and yellow machines were sold at industrial equipment dealers.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 1:55pm
My Allis road grader is of late 50s vintage, and it is yellow, painted over the top of orange. What I read about it, is that it was the first model of allis road graders that had the option of being painted construction yellow, or orange. Prior to that, orange was the only option. I would assume that dozers and crawler tractors followed suit. Darrel
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 2:38pm
Construction Equipment Division was formed in 1957 and changed to yellow paint around 1960, according to the Swinford book.  This seems right judging by the equipment I have owned.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 4:17pm
Manual for Allis "Forty Five" lists only Persian Orange.
Manual for Allis "45" (Allis Australia) lists only Allis Chalmers Yellow.
FWIW
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 6:24pm
OK to totally confuse you
My 1955 HD5G is orange ,
a 1953 HD5G I had was orange over yellow
A friends who had a 1952 HD5G - one of 4 the company owned - all were yellow
Another HD5G I scrapped was yellow - believe year was 1954
The HD5B had orange as primary but both frame rails by engine showed yellow under the orange on inside of rails - outside was orange down to bare metal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 7:44pm
I seem to recall that here in Oz that one state government started to demand that all their construction equipment be yellow.  And there went the individual firm colours and Cat's trading advertisment.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 7:53pm
 This was 1967  545 wheel loader
PPG Automotive Finishes
Tractor and Implement Colors
Caution: This list was assembled using three different PPG sources plus input from others. There was no information concerning model or year, except as noted. Use this list at your own risk. There are no guarantees. I have only confirmed the AC early persian orange, sometimes referred to as "persian #1", as 60080. Most of the codes should be available in most, if not all, current PPG automotive paint chemistries, including the economy OMNI line. See your local PPG jobber for details. I strongly suggest first purchasing the smallest possible quantity in an attempt to verify the proper shade. Custom mixed colors are not returnable. Unfortunately, whenever a color proper name has multiple codes listed against it, I have no idea which one is appropriate for your application. If you are particular about shade, you may have to sample them all. If you wish to get information on the different chemistries available from PPG, including technical data sheets (detailed usage info) and material safety data sheets (MSDS=safety & health info), go to the PPG website.
Rod (NH)
May 2006
Allis Chalmers Cream----------------------------------8638
Allis Chalmers Cream (Beige) - Trim Color-------------23056
Allis Chalmers Earth Removing Equipment Yellow--------81233
Allis Chalmers Earth Removing Equipment Yellow--------81611
Allis Chalmers Earth Removing Equipment Yellow--------81985
Allis Chalmers Lift Truck Yellow----------------------81475
Allis Chalmers Persian Orange (Persian #1, so called)-60080
Allis Chalmers Persian Orange (Persian #2, so called)-60396
Allis Chalmers Orange---------------------------------60691
Allis Chalmers Tractor & Equipment Orange-------------60856
Allis Chalmers Yellow---------------------------------81330
Allis Chalmers Yellow---------------------------------81960
Allis Chalmers Yellow---------------------------------82373
Allis Chalmers Yellow---------------------------------82630
Allis Chalmers Black----------------------------------9000
Allis Chalmers Black----------------------------------9300
American Crane Yellow---------------------------------82295
Blau Knox Yellow--------------------------------------82069
Bobcat Red--------------------------------------------72155
Bobcat Silver-----------------------------------------35388
Bucyrus Erie Yellow-----------------------------------82536
Bucyrus Erie Maroon-----------------------------------50743
Case Desert Sunset------------------------------------81357
Case Desert Camouflage--------------------------------25829
Case Flambeau Red-------------------------------------3116
Case Flambeau Red-------------------------------------70138
Case Flambeau Red-------------------------------------71282
Case Black--------------------------------------------9000
Case Black--------------------------------------------9300
Case Black--------------------------------------------9519
Case Dark Brown---------------------------------------25550
Case Power Tan----------------------------------------25549
Case Power Tan----------------------------------------26071
Case Gray---------------------------------------------32678
Case Corporate Red------------------------------------72898
Case Red----------------------------------------------73252
Case Medium Yellow------------------------------------82305
Case Power Yellow - Medium - #B-174-21----------------82308
Case Tractor Industrial Yellow------------------------89962
Case Tractor Orange-----------------------------------60432
Case Tractor Orange-----------------------------------60703
Case Tractor Orange-----------------------------------60906
Case Tractor Yellow-----------------------------------89952
Case Manila White-------------------------------------90393
Case White--------------------------------------------8857
Caterpillar Highway yellow----------------------------80979
Caterpillar Yellow (old - replaced by 80979)----------80021
Caterpillar Yellow------------------------------------81985
Caterpillar Yellow------------------------------------82454
Caterpillar Yellow------------------------------------83930
Caterpillar Yellow (Ford)-----------------------------81661
Caterpillar Yellow (GM)-------------------------------81993
Caterpillar Yellow (1996)-----------------------------82785
Caterpillar Yellow (1996)-----------------------------83922
Caterpillar New Yellow (most common)------------------82943
Caterpillar New Yellow--------------------------------88046
Caterpillar Tractor Yellow----------------------------80453
Caterpillar Tractor Beige-----------------------------22393
Caterpillar White-------------------------------------2185
Caterpillar White-------------------------------------98041
Caterpillar White (Ford)------------------------------8709
Caterpillar Mojave Brown (1997)-----------------------28605
Caterpillar Slate Gray (1997)-------------------------36435
Caterpillar Slate Gray (1997)-------------------------36457
Caterpillar Black-------------------------------------9000
Caterpillar Black-------------------------------------9300
Caterpillar Black-------------------------------------95020
Caterpillar High Gloss Black (1997)-------------------95021
Caterpillar Semi Gloss Black (1997)-------------------95022
Caterpillar Medium Gloss Black (1997)-----------------95023
Caterpillar Low Gloss Black (1997)--------------------95024
Caterpillar Interior Brown----------------------------25789
Clark Hi-Lift Olive Green-----------------------------40250
Clark Hi-Lift Yellow----------------------------------81689
Clark Lift Light Green--------------------------------2885
Clark Lift White--------------------------------------2185
Clark Lift Truck Fire Engine Red----------------------72203
Clark Lift Truck Gray (1965-1966)---------------------32583
Clark Lift Truck Green (1976)-------------------------42095
Clark Lift Truck Green (1977)(#1801564)---------------45415
Clark Lift Truck Olive Green (#1800641)---------------44705
Clark Lift Truck Orange (#1873147)--------------------60487
Clark Lift Truck Yellow (#1813150)--------------------81651
Clark Lift Truck White (#181570)----------------------8000
Clark Equipment Gray----------------------------------32123
Clark Equipment Green (#180642)-----------------------44540
Clark Equipment Green (#1800645)----------------------44205
Clark Equipment Orange--------------------------------60532
Clark Equipment Orange (Flat)-------------------------60533
Clark Equipment Yellow--------------------------------81302
Clark Equipment Yellow--------------------------------80502
Clark Yellow------------------------------------------81892
Cletra Orange-----------------------------------------60045
Cletra Orange-----------------------------------------60376
Cockshutt Tractor Red---------------------------------78210
Cockshutt Tractor Harvest Gold------------------------83761
Cockshutt Tractor Yellow------------------------------88234
Crane Company Orange----------------------------------60431
Crane Carrier Orange----------------------------------60583
David Brown Tractor White-----------------------------8638
Dempster Dumpster Gray--------------------------------31832
Dempster Dumpster Green-------------------------------45284
Ditch Witch Orange (New)------------------------------61540
Ditch Witch Orange------------------------------------60862
Euclid HIlite Green-----------------------------------45771
Euclid Maroon-----------------------------------------50743
Euclid Yellow-----------------------------------------82536
Ferguson Gray-----------------------------------------30419
Ferguson Gray-----------------------------------------32830
Fiat Allis Orange-------------------------------------60740
Fiat Allis Yellow-------------------------------------2325
Ford Beige--------------------------------------------33186
Ford Gray---------------------------------------------30570
Ford Gray---------------------------------------------32663
Ford Gray (1948 & 1954)-------------------------------32675
Ford Yellow-------------------------------------------82536
Ford Light Yellow-------------------------------------82549
Ford Red----------------------------------------------2833
Ford Red (1947)---------------------------------------70075
Ford Light Red----------------------------------------72598
Ford Equipment Dark Blue------------------------------12908
Ford New Tractor Red----------------------------------71969
Ford New Tractor Silver-------------------------------33442
Ford Tractor Blue (1962)------------------------------12720
Ford Tractor Blue (1963-1965) - M20J1639A-------------12809
Ford Tractor Buff-------------------------------------81339
Ford Tractor Gray-------------------------------------30448
Ford Tractor Gray (1965) - M20J1750-A-----------------32571
Ford Tractor Gray (1965)------------------------------32571
Ford Tractor Green------------------------------------42940
Ford Tractor Yellow (20J3132A)------------------------82179
Ford Tractor Yellow (New) (M2J5394-A)-----------------82291
Ford Tractor Orange Red-------------------------------71346
Ford Tractor Vermillion (1949)------------------------3155
Ford Tractor Vermillion-------------------------------70205
Ford Tractor White------------------------------------8712
Ford Tractor & Implement Buff #1640 (1967)------------22914
Ford Tractor & Implement Buff (1967)------------------4068
Ford Tractor & Implement Buff (1967)------------------4119
Gallion Highway Yellow--------------------------------80020
GM - Terex Green--------------------------------------2960
GM - Terex Green--------------------------------------2963
Gravely Tractor Beige---------------------------------22136
Gravely Tractor Red-----------------------------------70186
Gravely Tractor Mustang Red (Orange)------------------60524
Husky Tractor Gold (FMC)------------------------------22390
Husky Tractor White (FMC)-----------------------------8377
Hyster Yellow-----------------------------------------82373
International Cub Cadet Yellow------------------------81518
International Cub Cadet White (IH-901)----------------8665
International White (IH-902)--------------------------90592
International White (IH-935)--------------------------91607
International Apple Green #2--------------------------40055
International Blue------------------------------------10067
International Red-------------------------------------2833
International Red (Light) #50-------------------------70019
International Gray #112 (Light)-----------------------30074
International Gray #110 (Dark)------------------------30031
International Green Apple-----------------------------40250
International Harvester Red IH-2150-------------------71310
International Harvester Brown-------------------------20048
International Harvester Tan #31-----------------------20214
Jacobsen Power Lawnmower Orange-----------------------60459
Jacobsen Power Lawnmower Orange-----------------------60816
Jacobsen Lawn Tractor Orange--------------------------69916
John Deere Brown (Low Gloss Interior)-----------------28374
John Deere Construction Yellow------------------------81518
John Deere Contracting Equipment Yellow---------------81304
John Deere Dark Brown---------------------------------26151
John Deere Green--------------------------------------40249
John Deere Green--------------------------------------47910
John Deere Implement & Product Division Yellow--------82009
John Deere Industrial Yellow--------------------------82295
John Deere Industrial Yellow--------------------------83018
John Deere Industrial Yellow--------------------------83558
John Deere Industrial Dealers Yellow------------------81638
John Deere Snowmobile Green---------------------------45117
John Deere Tractor Green------------------------------41374
John Deere Tractor Green------------------------------46180
John Deere Yellow-------------------------------------80186
John Deere Yellow (1967)------------------------------81687
John Deere Yellow (1967)------------------------------81058
John Deere Yellow (1967)------------------------------81986
John Deere Yellow (1991)------------------------------83416
John Deere Yellow (1995)------------------------------81512
Kubota Orange-----------------------------------------60550
Kingboy Tractor Yellow--------------------------------82744
Komatsu Yellow----------------------------------------2381
Komatsu Yellow----------------------------------------82261
Komatsu New Yellow------------------------------------83059
Komatsu New Blue--------------------------------------17080
Komatsu Orange----------------------------------------60583
Marion Power Shovel Co. Charcoal----------------------32728
Marion Power Shovel Co. Neutral gray------------------32727
Marion Power Shovel Co. Red---------------------------71706
Massey Ferguson Red-----------------------------------72598
Massey Ferguson Silver Mist Gray (Met.) (M-1037)------31991
Massey Ferguson Yellow--------------------------------81518
Massey Ferguson Tractor Flint Gray (M-1026)-----------31645
Massey Ferguson Tractor Flint Gray (Met.) (M-1025)----31644
Massey Ferguson Tractor Red M-1017--------------------70837
Massey Ferguson Tractor Yellow M-1023-----------------81217
Massey-Harris Red-------------------------------------70364
Massey-Harris Red-------------------------------------70837
Massey-Harris Yellow----------------------------------2492
Massey-Harris Yellow----------------------------------80533
Minneapolis Moline Dyna Brown-------------------------22394
Minneapolis Moline Dyna Brown #2 (1967)---------------23049
Minneapolis Moline Orange-----------------------------60740
Minneapolis Moline Prairie Gold-----------------------60098
Minneapolis Moline Prairie Gold #2--------------------60039
Minneapolis Moline Red--------------------------------71528
Minneapolis Moline Red--------------------------------70385
New Holland Tractor Red-------------------------------72263
New Holland Tractor Yellow----------------------------82348
Oliver Clover White (1959)----------------------------8229
Oliver Clover White (1959)----------------------------8805
Oliver Cletrac Orange---------------------------------60583
Oliver Equipment Dark Charcoal------------------------33768
Oliver Equipment Dark Charcoal------------------------34347
Oliver Equipment Dark Charcoal #90833-----------------33194
Oliver Equipment Green (1959)-------------------------42638
Oliver Equipment Silver Poly (Met.) #90832------------8960
Oliver Equipment Green (1959)-------------------------41223
Oliver Green------------------------------------------45132
Oliver Green------------------------------------------40249
Oliver Green------------------------------------------40812
Oliver Industrial Yellow (1959)-----------------------81154
Oliver Industrial Yellow (1959)-----------------------82335
Oliver Orange-----------------------------------------60433
Oliver Yellow-----------------------------------------81892
Rex Chain Belt Bright Green---------------------------45284
Rex Chain Belt Bright Orange--------------------------60691
Rex Chain Belt Medium Gray----------------------------31576
Rex Chain Belt Medium Green---------------------------44665
Rex Chain Belt Yellow---------------------------------81985
Sperry New Holland Red--------------------------------61026
Sperry New Holland Yellow-----------------------------82536
Thew Lorain Shovel Co. Brown--------------------------22312
Thew Lorain Shovel Co. Yellow-------------------------81329
Toyota Fork Lift Orange-------------------------------60156
Versatile Tractor Red---------------------------------72233
Warner-Swasey-----------------------------------------82073
Wheel Horse Tractor Red-------------------------------72034
White Farm Tractor Blue-------------------------------12773
White Farm Tractor Orange-----------------------------2235
White Farm Tractor Red--------------------------------72231
          http://personalpages.tds.net/~thompson_wp/misc/PPG%20Tractor%20Colors.htm
Caterpillar Highway Yellow
DT2107 80979
Cat#94878
88046
82943
most common colo
    B:-)      dnoym
Edited by Dnoym N. S. Can. - 07 May 2016 at 8:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 11:03pm
I knew I'd get some interesting responses with a question about paint color.
dnoym, that's an over-the-top response. I'll hard copy all that for my files.
Thanks, AC guys.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2016 at 9:00pm
We are painting a 1956 D grader at this time. We are using national school bus yellow, which I was told by the former service manager @ Cooke Sales and Service in Chillcothe, MO was the correct color for AC construction machines. Light industrial used the PPG 81985, which our tractors are refinished in. I do have several paint formulas in another notebook that I can provide as well. I will also provide the Hentzen number for the yellow we are using on the grader.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2016 at 11:36am
I read in one of many AC books I have, I think, all ag tracked equipment was Orange, all others was yellow with a hard nose. But But But they could be ordered either color. My HD6G's have all been yellow but the last motor I purchased from Clapp Brothers came from a Ag cat and it was a higher HP orange engine.
