620 Front clutch problem
Darrell, Jr. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Topic: 620 Front clutch problem
    Posted: 03 May 2016 at 8:31pm
I think I have a problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 9:59pm
can anyone tell me if this is a terminal problem or what I need to do to fix it?  If you can't see from the picture, the plate that is on the front side of my front electric clutch is off-center.  any help would be nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2016 at 10:11pm
Darrell, pretty sure the pressure fingers are broke . They actually don't pressurize it, but when current is applied, they allow the magnets to pull the plate to flywheel. I think warner electric is the maker. A better pick would help. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 10:27pm
Tracy, Yes there is 1 or 2 pressure fingers broken, can these be replaced?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2016 at 10:43pm
Darrell, I would think so from a parts clutch. HTH Tracy
