1939 B Carb
Bob Landers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob Landers Quote  Post ReplyReply Direct Link To This Post Topic: 1939 B Carb
    Posted: 10 May 2010 at 10:01pm
I have a Marvel Schebler TSX-159 carb.  I'm wondering if it will work on my 1939 B?  If so, do I need to modify it?  I'm thinking I may be better off buying a new one.  My tractor is a hand start.  Thanks for your advice.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 10:21pm
My first thought would be are the bolt patterns the same or is the 159 wider?
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2010 at 7:04am
I think you will find it is too big {bolt pattern} and may be jetted for a larger ci engine. Would probably fit a WC or WD.
I have had good luck with the new Zenith carbuertors.
I have this carburetor on both of my C's
http://www.thecarburetorstore.com/servlet/Categories
Edited by Jeff Z. NY - 11 May 2010 at 7:17am
