Pull Results
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Pull Results
    Posted: 02 May 2016 at 7:26am
Just posting results from our last club pull so you can see how AC does.
Of interest is that in 4000 class, 3 of us stopped within 5 feet of each other, while 2 others put 65'+ on us. Gary has a WC, not WD, running 14.9x28's and Jerry has 16.9x28's.
Rothgeb has 16.9x28's and I have 14.9x28's.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2016 at 1:48pm
I used to run with the Menifee's Farmall B a few years back. At the time I was only running 2nd gear in the 2500 pound class and Carrie was right with us all the time.  What is the speed limit and tire restrictions for the "B"  and "C" classes. They didn't have those back then.
Edited by PaulB - 02 May 2016 at 1:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2016 at 2:23pm
A and B are stock size + 1 size. So 13.6 can use 14.9. No increase in diameter.
C is 38", I think 14.9 up to 4500 then you can go to 16.9
A is first gear only (Stock/showroom tractor)
B is 3.5 mph
C is 6 mph
Yes his B is pretty darn powerful. I don't think I have ever seen him power out. He always was outside of the box thinker back in the day. I heard his 560 gas was the tractor to beat where ever he went.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2016 at 7:16pm
When they built that tractor for Carrie when she was in school, I was involved with some of the gathering up of needed part. I know where that little tractor gets it's power from, but I can't tell secrets about someone else. But anyone that want big power from a little AC engine I can help. As always the first question is "How much do you want to spend?"
