Bearing dilemas
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Bearing dilemas
    Posted: 01 May 2016 at 8:01pm
Ok, so rebuilding the pulling wd, was going to use a wd block with a 45 crank and 1/8 inch over bore pistons but it ended up the wd block was cracked aND the Web in between number 2 and 3 was sunk down. Ended up using a wc block instead. The bearings came with the wd 45 crank. Here is what my grandpa posted on yesterday's tractors , I haven't seen the problem yet we talked over the phone about it.
Got a WD45 crank that I had ground a number of years ago and got bearings for it at the same time. Going to put it in a WC block and I noticed the oil hole in the block is towards the front while the oil hole in the bearing is in the center. Is there a difference in the front bearing from a WC to a WD45? Also middle and rear bearing have room for .011 shims while front has room for .017 shims which seems like a lot. Thanks.
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2016 at 6:37am
I was just setting in my bearings and 45 crank over the weekend into my 45 block. I noticed that the front bearing oil hole did not come straight up like the other 2 bearings. It was ground a little off to the side to move the oil over to the centered oil hole. On mine only about half of the oil passage lined up with the bearing so I ground it over a little more with the die grinder. I thought I had a picture, but I only took picture of the hole with the bearing in.
