Daydreaming
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Daydreaming
    Posted: 28 Apr 2016 at 12:08pm
What would it take to build a competitive antique puller (Pre 1960) for the 6 mph class?
Has to use stock block or (226 series)
Updraft carb
Stock manifold
16.9x38's top cut
20% over RPM's
say 3500 lb up to 5500
Charlie
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 4:20pm
this is similar to NATPA DIV3  except DIV3 is 4mph now instead of 3.5
i see very few AC tractors competing above 4000 lbs when i look through the points so it may be pretty tough
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 5:44pm
So would 120 hp do the trick ? If so, then punch and stroke a 226 to 350 - 390 cubes. Don't know what you would do for gearing, maybe a early D17.  That would have to get you in the ballpark.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 12:19pm
Always remember, an "M" Farmall and "88" Oliver can reach 500-550 plus cubes and the little West Allis engine is stretched at around 450.
