HD6, need a part
NoelC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NoelC Quote  Post ReplyReply Direct Link To This Post Topic: HD6, need a part
    Posted: 28 Apr 2016 at 9:01am
My father has an HD6, looking for a replacement part I can't seem to find. He called it the Input Shaft Seal on the transmission. Does anybody happen to know where I can find/order one? Thank you.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 9:21am
Minnpar has parts books you can lookup your seal # and they will probably have it.
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 11:08am
There are two different type  seals, from #19771 on HD6A,B and #19867 on HD6E a lip type seal #CR 26190 which are common seals earlier tractors have a bellows type seal which Minnpar will have, there is a company in Italy that make replacement seals for Allis rollers, idlers and final drives. the earlier part number is 082876 the Fiat Allis number will have a 70 or 7 prefix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 10:47pm
General Gear in Idaho have the early type seal $74.
