AC 8550 Transmission HELP
bkrapp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkrapp Quote  Post ReplyReply Direct Link To This Post Topic: AC 8550 Transmission HELP
    Posted: 10 May 2010 at 9:56am
Hi there, we recently bought an 81 AC 8550 with around 7000 hours.  The tractor runs and worked perfectly for about 30 hours of field work this spring for us.  We were rolling beans yesterday and just as we kicked the foot button on the floor into high after turning a corner it started grinding very badly and the tractor stopped moving.  It makes a high grinding sound kind of like when a starter is grinding on the ring  gear but louder.  It doesn't make the sound out of gear, only when the tractor is put into gear.  I am wondering if any of our have a diagram of the parts  you feel this would be or if you have some knowledge of this and if there are weak points in these tractors.  looking in my service manual, it looks like there are some couplers in between the drop box and the transmission.  If anyone could elaborate on this I would really appreciate it. My manual is a copy and you can't see the pictures worth a hoot.  Also if anyone would have or know where parts for this would be would be great.  I thank all in advance.  Thanks
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 11:31am
You can go to www.agcopartsbooks.com and look at the book online. I think the 8550 still had the same transmission as the 7000 series tractors and same drop box as 7580 but they had different gearing. Does it move in any combination of gears or ranges, maybe even in neutral. Does it want to die when the clutch is let out? How was the oil level in the transmission?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 11:45am
8550/4W305 are a totally different tranny and parts might be hard to come by. I do know they are good at drop box failures of some kind....may be the issue here/?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkrapp Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 11:50am
No it doesn't move in any combination of gears.  It doesn't wnat to die, it just grinds like something stripped out.  The oil level was good.  Thank you for the info and any help you can give me.
Blake
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 12:03pm
Shift the 5 speed into any gear and leave the range lever in park.....see what the sound is like then with the clutch pedal up.
Cb NwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cb NwO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 12:22pm
Where did you get this 8550 from?
robo123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robo123 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 2:18pm
Sounds to me like maybe you striped the splines out of the middle of the Power Director clutch hub.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 11:33am
Here is a posibility for some parts.
8550 Parts tractor
This page was generated in 0.085 seconds.
