Highest horsepower and the most common Allis?
Daniel Christensen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Topic: Highest horsepower and the most common Allis?
    Posted: 09 May 2010 at 9:54pm
Which model of Allis Chalmers was rated or tested at the highest horsepower? And which one was the most common in the number of them built? Wasn't the most common one the WC? There were about 178,000 of them made.
Edited by Daniel Christensen - 09 May 2010 at 10:45pm
CAx3, Bx2, G, D17x2, D14x2, D15, D19, 190XT, WC, WD-45, 185, Gleaner K.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 10:25pm
I think at their peak, their were more more of them on farms than any other model. I find that amazing if true, due to the number of Fords, but they may have not been the same model.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 10:56pm
The highest horsepower farm tractor that was produced was the 8550 and the 4W-305, both rated at 305hp. The 8550 had 7000 series sheet metal and the 4w-305 had an 8000 series cab with one of a kind sheet metal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 11:43pm
I see. That's pretty big. 300 horse engine. Prolly close to 250 drawbar. Not quite the 400+ drawbar HP a couple of these newer tractors have. I have yet to know of a production tractor that has 500 actual drawbar HP tho. Maybe a 500 or more HP ENGINE, but not drawbar power.
Take the John Deere 9630 for example:
John Deere 9630 Power:
Engine:530 hp [395.2 kW]
Drawbar (tested):427.14 hp [318.5 kW]
See that it's got more than a ONE HUNDRED horsepower difference between engine and drawbar!
Edited by Daniel Christensen - 09 May 2010 at 11:44pm
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 11:46pm
look up    big bud diesel 747 thats over 500 easy.
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 11:50pm
When you say look up, I wrote the article on it:
so believe me I know about it lol
I meant in production tractors though, there is not 500+ drawbar HP. And also by the way I have no idea what the actual drawbar HP is on the Big Bud. Only the claimed ~900 engine HP. However, with such an engine HP, I'm sure the drawbar is over 500 :)
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 4:24am
We have a dam near here with 3 or 4 Allis Chlamers Hydroelectric turbines, each producing 2200 hp  :)  Got a tour there one day and was totally impressed, they've been there spinning since the early part of the last century.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 7:23pm
I have heard the WC was highest volume Allis model but never looked to check.
Not sure what model would be highest if you count all makes.  Deere and Farmall had some long running models in their lines too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 7:37pm
I believe I read somewhere once that there were 750,000 or so Fordsons built. They were way out ahead of anybody as far as production of one model.
http://www.ytmag.com/atrp/prodnum.htm
Here are some production numbers listed.
Edited by CTuckerNWIL - 10 May 2010 at 7:56pm
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 7:50pm
  hp. today an the wc .s days are computerd different   wc was brake hp.   today it is computered hp.  no comparision in my book  my 2 cents
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 8:38pm
8050, we have at least two dams within 15 miles of the house. They both have AC generator units. 6 each I believe. Also have another lake in the Savannah river system down below Hartwell and Russell. It may have AC units, i'm not sure. That's a LOT of combined HP!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 10:49am
Wait, yes, How is horsepower calculated nowadays vs back then? I imagine the newer way would be the more inflated, generous, non accurate way.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 1:53pm
CTuckerNWIL, notice how so many Deere end in even numbers like 3000,000 or 30,000 or 160,000. They aren't an accurate numbers. Just estimates. Deere lovers will argue it to their last breath but it's true. I went through the numbers once years ago and could only account for about 240,000 or 260,000  A's. Compare that to the WC and WD which combined are at over 324,000 for the same years. I know the model designation changes but the tractor has no more changes than an early A to a late A, probably even less as the engine from a WD to a WC isn't very different and the gears in the tranny will swap.. That tells you that there were and are a lot of Allis's of that era.
Wink
I am a Russian Bot
This page was generated in 0.067 seconds.
