What octane fuel ?
YT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote YT Quote  Post ReplyReply Direct Link To This Post Topic: What octane fuel ?
    Posted: 21 Apr 2016 at 8:39pm
I know there are lots of variables, but what octane of fuel would one use if cranking pressure is around 200-210 psi?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2016 at 10:06pm
100 to 104 should be good enough. Your total ignition timing (at full throttle)should be around maybe 20 degrees?? and set on a dyno to verify that is the best timing setting. Stock timing of 25 to 30 degrees BTDC is too fast with that much compression.
YT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote YT Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2016 at 6:56am
Thanks Doc. Hopefully be on the dyno this weekend.
