CA Oil Pressure Gage Flutter
Turbo_760 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo_760 Quote  Post ReplyReply Direct Link To This Post Topic: CA Oil Pressure Gage Flutter
    Posted: 17 Apr 2016 at 9:00pm
I have been working on getting my CA back into shape.  I have recently noticed that the oil pressure gage flutter once the engine gets warmed up. It probably flutter 2-3 psi really quickly.
When starting the engine it will have over 10PSI on the gage and the needle will continue to flutter around 10 PSI when warmed up at high idle.  At idle the gage will drop down to ~ PSI and flutter.
Is the flutter normal?
1951 CA
Cub Cadet 149
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo_760 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 10:44pm
I have noticed the this behavior occurs after the engine has been warmed up a little, but does seem to go away once the engine is fully warmed up. I suspect that this could be caused by the oil pressure regulator
Video (click on picture)
1951 CA
Cub Cadet 149
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 6:48pm
I think it's most likely your gauge.  Have you tried a different gauge?
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
MrHDC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrHDC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 7:43pm
I'm with Hub. Try another gauge.
Hervey
