Tach Drive Adapter Installation
fmutiger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fmutiger Quote  Post ReplyReply Direct Link To This Post Topic: Tach Drive Adapter Installation
    Posted: 15 Apr 2016 at 9:54am
Where and how do I instal a tach drive adapter and cable on a Allis Chalmers D-17 Series II Gas?
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 10:35am
a factory one goes in the back of the governor as long as it has a slot in the governor shaft Niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote fmutiger Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 10:41am
I still have the factory Distributor, but ordered the tach, cable, nipple and adapter from Steiner. My D17 never had one I take it and wanted to put one in. I was assuming if I took that large nut off the back of the distributor, there should be a space inside to slide the adapter through?
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 10:49am
yes.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote fmutiger Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 10:51am
didnt know if it was that easy or not, the nut looks alot larger than the nipple that supposed to go on there. the male end of tha tnut must not be as large as it looks outside
