cutting tires
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Topic: cutting tires
    Posted: 14 Apr 2016 at 7:19am
I'm getting ready to buy a new set of 23 degree tires, and I'm wondering what the best way to cut them is? Is there anybody in the southeast I can take them to and have professionally cut? My local tire shops won't do it. If not, how do y'all cut yours? What tools should I be looking for, and what cut should I aim for? They are 16.9-38, 23 degree tires on an antique pulling in first gear with a 3.5 mph speed limit. Thanks in advance!
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 8:04am
You'll be disappointed with brand new tires---rubber too soft. Find old used tires that are worn down some and hard.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 8:46am
Saw this first hand, watched the cleat just bend back under hard pulling
Find some 23 degree worn ones?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 7:43pm
Theres a product out there called a hot knife; it heats up and cuts thru the rubber, then theres the grinding wheels/ blades set up to do this on a 4 or 8 inch grinder; its a dirty job
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 8:00pm
a good running small chain saw will do a dam good job' then shape them up with your grinder' works nice. if you can handle the saw''
millertire View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote millertire Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 8:57pm
Miller Tire as grinding disc in stock, see link;
http://www.millertire.com/categories/tire-supplies/grinding-disc/
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 10:43pm
I used an electric planer be sure to spray a little WD-40 down first
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 6:01pm
 I wondered if an electric planer would work for top cutting the bar, if it works for you I will try it.
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 6:29pm
I've used an electric planer for years to shape the tops of the lugs. Consider a hospital visit if you going to use a chain saw !!! Good Lord.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 7:28pm
thats if you can't handle the saw' i cut the top of the lugs off then take a 4'' wheel an make them nice. did lots of them like that but you got to know how to run a good saw thats all
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 7:39pm
Ok, do I would be best off with a hard tire? Also I'm running a 14 inch rim, would I be better off running a 15.5-38?
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 7:50pm
i run a 17" wide wheel on my 15.5 x38 it helps flattens the lugs out
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 9:34pm
like pat' said it's better with the wider rim to let the center of the tire be  more flat so all the tire is working' not just the center of it.
