1976 7000 AC
7000will View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7000will Quote  Post ReplyReply Direct Link To This Post Topic: 1976 7000 AC
    Posted: 09 May 2010 at 12:10pm
1976 7000 AC for sale.
Actual Hours are unknown as I purchased it with a non working tach. Cab great heater, needs AC Pump, and radio. Cab is good but I have a new kit and mat for it that goes with it. Cab is showing surface rust but not rusted out. Glass and rubber excellent. Power shift with factory triple hydraulics and long axles. Full set front weights. Front rubber new 3 years ago and in good shape. Rear tires are ok but are showing some splits in the sidewall. Pto works good, all hydraulics work good. Has a new clutch, pressure plate, and throwout bearing this past fall and has only been used to blade the driveway since intalled. Has been used in 06,07,08 for haying, a little vibra shank work, and drilling. 09 and 10 has sat in the barn and been used for driveway and mowing. Shows some blowby but uses no oil.
To be field ready it needs a current oilchange, fix a small leak in the forward oilcooler, and check the hydraulic oil. Also has one new battery. Great swathing, raking, baling and planting tractor. Im a straight shooter and can be found with 100% ranking on ebay, look for 2606will. The only thing I know that is wrong is the leak by the front cooler and I have experienced the tractor come out of reverse on occasion when I would back up to kick out a bale.  The paint is original on the sheetmetal but the belly is maroon and has been repainted. All sheetmetal is in very good shape. If you are interested just drop me a reply and I can get you pictures. Thanks!
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 12:53pm
What are you asking for the tractor? I am looking for one to put a factory canopy on , make it a fender tractor.
                IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7000will Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 8:37pm
Im asking $5500 but will take offers.  I looked it over again and it also will need an exhaust elbow. Let me know if you need pictures. Thanks
This page was generated in 0.049 seconds.
