HD14 serial number location? |
colesdaddy
Topic: HD14 serial number location?Posted: 14 Apr 2016 at 12:22am |
Hello all, we're getting ready to sell and I need help locating the serial number on a HD14. I can't find it even though tractordata says it's "behind transmission case, right side." Anyone have a better description? Thank you in advance.
Ages Cat
Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 700 |
Posted: 14 Apr 2016 at 8:39am |
Upper right hand corner as you face the rear of the tractor. They can be coverd up if the tractor has a winch.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025, |
colesdaddy
Posted: 14 Apr 2016 at 8:55am |
Well then that could explain it. It does have a large ex-military winch. Is the serial number on a plate or stamped? Thank you again for the help.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 14 Apr 2016 at 9:23am |
this is a HD19 but It will STAMPED where the circle is
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, 2-S77, HD15 |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34636 |
Posted: 14 Apr 2016 at 10:19am |
HD14 had the same rear end as the L had and they were stamped on top of a horizontal surface down on the right side of rear case. They were not a big hunk of steel squared off like other crawlers were, they had the transmission behind the ring and pinion.
The truth is the truth, sugar coated or not. Trawler II says, "Remember that." |
CAL(KS)
Posted: 14 Apr 2016 at 10:28am |
oops. thank jc. I just assumed the 14 was similiar to the 10 and 7
JC-WI
Posted: 14 Apr 2016 at 1:06pm |
an its new version, the HD15...an the bigger version of the 15, the 19.. LOL
colesdaddy
Posted: 15 Apr 2016 at 9:38am |
Thanks guys. There was a little dust on it but I found it. According to tractordata, it was made in '44.
