545 wheel loader operation
Grader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Topic: 545 wheel loader operation
    Posted: 12 Apr 2016 at 9:18pm
Can anyone tell me about the operation of a 545 wheel loader. Specifically a locking torque converter??? All the labels are very faded inside cab and can't find much on the net about it. It has the 301 Diesel engine as I just got it running tonight. It has sat for 15 years or so. Also any pros or cons to this machine? Any info is greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 11:10pm
Not really a locking converter.It's a two stage and has sprag which can be know to quit holding.if fluid is up it should spin the wheels when up against a BIG tree
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 6:57am
Is there a lever inside the cab that does this or does it engage on it's own. What can be done to fix this?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:15am
Grader, I am guessing that your new purchase does not "go" when you put er in gear and mash the throttle to the floor......? First thing, check the transmission fluid. Then check the shift linkage to make sure that when you move the shift lever, that you are actually engaging the transmission. There is no lever to lock up the torque converter. It is just an automatic transmission; put it in gear and put the coals to er. My 645 does have a weak transmission. It won't hardly spin a tire, but does get the jobs done for us that we need it to do. We did discover a while back that due to to the way the throttle linkage was, we wern't getting full RPM's out of the engine. When we fixed that, those few hundred RPM's made a world of difference. Keep playing with it, hope you get er working. Keep us posted! Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:23am
The lever on left column ,center-lift for start,fwd has 2 notches/speeds,reverse pull back.Some trans have 2 fwd & rev.Mines single rev.
whats your serial No. On the oil tank behind seat
Edited by SteveM C/IL - 13 Apr 2016 at 9:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 9:59am
I'm not sure. I'll get the serial numbers tonight. The loader was dam cheap so I had to buy it being I'm an allis guy. Came with bucket and forks. I only seen the shuttle shift on the colum had forward and reverse. Where would the other forward speed be located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 11:41am
The shifter on the column should have 2 positions in forward, high and low. You would push the lever ahead against a stop for low, then pull the lever towards you and push it ahead against another stop for high. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 11:57am
There was also a small lever on the right of the seat. It was froze up. Any clue what this might be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 2:47pm
There is a small lever on left of seat as you set,up high on oil tank.Trans "disconnect" when braking.Only used on flat ground because machine will roll into whatever before trans takes hold when brakes release.Nothing on rt in mine cept hyd levers and fuel shut off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 3:21pm
I'll take pictures and try to upload them.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 6:14pm
It's not too likely but worth checking that this transmission disconnect valve isn't stuck in the "disconnect" position. If you get a manual for the Allison transmission you can do some pressure checks and find out what's working and what isn't. It's really good if you got it started without too much trouble after 15 years of sitting, you can at least tow it home with loader and steering working. Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 8:43pm
I started in tonight and drove it out of it's grave. Two tires were up and the other two flat as can be. It pulled rite out of it's hole in first gear. And when I say hole it's belly was in the dirt. I was stopped and shifted to second and put the throttle on the floor and it kinda lunged a little bit not much else. I realize that's just a road gear so would that be normal to not move in 2nd with two flat tires?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2016 at 9:24pm
It might be enough to keep it from going in second.Two flat tires create a lot of resistance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2016 at 9:22pm
Well got the loader moved tonight. Was a little sketchy loading after it fell through the trailer floor that I had borrowed. That's just my luck. But needless to say it's home. I think the trans is ok. Was rolling backwards in reverse slightly and put into 1st gear and it locked up good and solid. It seemed to want to take off pretty well in 2nd while going across the yard. Trans fluid looks like it came out of the jug. Loader has sat for 13 years untouched. I would upload pics but can't figure put how from my phone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2016 at 8:41am
That's good to hear, except for the part about the trailer floor. I thinks ya got a pretty good buy. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2016 at 9:13am
Mine has dexron in both trans and hyd.Good thing too because it's transferring fluid
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 11:44pm
Say there Grader, do you have any updates for us on the payloader purchase. .? Is it working good and you so busy playing with it that you don't even have time to log on? Lol. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 1:41pm
Well Darrel I honestly haven't had time to mess with it for finding mushrooms and catchin crappie. I did buy some gauges for it the other day. I wish somebody could step me through posting pics from an I phone. I did talk to a guy that was around it when it ran. Said the trans was good if you were loading hay but if you were scooping dirt that is slipped. I have not had the machine to operating temperature so it's hard telling what it may do. I'm thinking a good servicing may do some good. Should I change fluid too??? It looks as it came straight out of the jug and doesn't smell burnt either. I'm all ears what do you guys think???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 1:43pm
Oh and I forgot. Shot a turkey Monday morning too. So now waiting til next week to bag the other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 10:22pm
I don't know what to recommend on the transmission fluid. Maybe pull the plug on it after it has been sitting for a few days, and see if any water comes out first. If you get some water, then I'd probably change the oil. I'd definitely change the engine oil. Hope someone gets you schooled on posting pictures, because I'd like to see the old girl. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 9:50pm
Pull the plug on trans filter and see if you have any metal.rt side behind cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2016 at 1:14am
I always used 30w engine oil in the transmission of my 745. You get better pressures when the transmission has enough wear that tolerances are marginal. Dexron trans. fluid gets very thin when hot and allows for more bypass and slippage.
You sure got a good deal on that machine! Hope it didn't cost you too much to fix that trailer floor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2016 at 9:37pm
Will the 30wt hurt it? What does it call for in the 545? It has dexron in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2016 at 10:30pm
I was looking online for Allison rebuilders etc,.....there was a place in TX and everything they published said 15w40 engine oil in trannys.Some other member chimed in from another country and he said 15w40 was the going thing in his local.
Straight 30 might not be so good in winter weather but in summer probably don't matter.
Edited by SteveM C/IL - 02 May 2016 at 10:32pm
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2016 at 8:16am
Grader.....you need to read this post by TedJ. Posting Pictures on the Forum Hope it will help you get some pix for us too see.
'39 Model B
Tractors are cheaper than girls, remember that!
This page was generated in 0.463 seconds.
