G 230 6 cyl swapped into a D 17 diesel
E Olson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E Olson Quote  Post ReplyReply Direct Link To This Post Topic: G 230 6 cyl swapped into a D 17 diesel
    Posted: 10 Apr 2016 at 11:32pm
Hi new here just picked this up, it's 1959 D17, it was originally a diesel but someone put in a 6 cyl gas engine... The plate on the engine says G 230, and the part # is #4514750...  I was told it came "from a combine", anyone know where I can find any info on the engine??? It does run very well and everything seems to work niceSmile Don't think the back wheels are original but Im clueless with these things... Any info would be appreciated.... Thanks
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 12:08am
Look at Gleaner A combine specs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote E Olson Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 8:11am
Thanks, tried finding that but not much out there going back that far... It was painted blue before it was orange....
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 8:45am
Looks like the rears are also off a combine
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 9:14am
Nice tractor.    Is the loader mounted in the rear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 9:14am
Engine specs probably easier to find under an A-2 Gleaner and still would be the same as a D-19 tractor except for the bore and stroke. All tune-up specs would be the same as a D-19 gasser.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 9:27am
Nice looking tractor! Congratulations and welcome! lots of good AC information here too.
That should be a good addition to the family! Loader would be nice some days!
regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 11:17am
Looks like the rear part of that loader is missing!?  BE DARN CAREFUL with it!  The only blots holding it on look like the 1 on the front and the 2 in the mid section.... I'd show some better pics and ask the gurus on here about it before I would trust it.  Just a word of warning....
It looks great though!!
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 12:05pm
They also put those in the Massey combine. Can't tell you the number of the combine but they did a good job and ran a long time. Leon R  Cmo
Post Options Post Options   Thanks (0) Thanks(0)   Quote E Olson Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 2:57pm
Thanks.... No the loader is missing the parts that go under the rear axle but its working well at least... I have a friend in the welding business Im gonna ask to see if he can make me something... Its a Koyker loader but I cant find any info on it as far as what model it is, I could probably buy the parts from them if I knew what model it was, they are here in SD... I have no real need for it right now but I will soon and we'll get it right.... I mostly bought it and  a post hole digger to use to build a deck and some fencing but I can see were gonna find a lot of work for it around hereBig smile
Tried messing with the points, they were at .35 and I set them at .22, it had a little miss to it that went away and a little more power but I think it's still not right... The plugs, wires and cap and rotor look newer and it does run very smooth, no smoke out the pipe but it seems weak under load... There is hole underneath that I can see the flywheel/clutch through, I can set the timing through there right??? What kinda marks do I look for??? Id like to put a pertronix conversion in it, anyone know a part number to look for???
This is my first tractor, never even drove one before so I really dont know what to compare it tooLOLEmbarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote E Olson Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 2:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote E Olson Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 3:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 3:11pm
that engine has about the same power as the 226 engine if I remember right...
Fellow had one with the 262 in it, said it had lots of power, and drank LOTS of fuel too. LOL
 since it was a combine engine, you should check to see if it has a full govenor in it or still the old governor whiich was limited until it got to full throttle. Picture of carb looks like its been changed... but you might still have the old goernor... maybe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 3:44pm
That loader needs to be moved back and bolted to the rear axle. Put any kind of load in that bucket and best case scenario you shear the bolts on the frame rail. Worst case you bend the frame rails and have a real mess.   I would find a good allis loader they look better and were made for the tractor.
Congrats on your first tractor. It looks nice under the loader. Lots of info on this forum. Thats one of the most popular models.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 4:11pm
The timing is set using the hole in the right side of the torque tube (close to the frame rail), as seen in this picture...
Post Options Post Options   Thanks (0) Thanks(0)   Quote E Olson Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 4:11pm
Thanks I looked at it and the holes are there on the frame to move it back, I'll still need to make some parts to bolt it to the axle but that will make it easier to do for sure...  I didn't put it on there but that makes a lot of sense to me!!!
Honestly as long as the loader works and this one does I don't care who made it but I do want it done right... Like I said I don't know much about this stuff and it's my first tractor so I can't say Im loyal to any brand in particular LOL
There are some other things that Im gonna fix that seem half assed on it...
Gonna try some fresh gas in it and then pull of those side panels and look around in there... I have no clue what the difference between a tractor and a combine governor is or even what it would look like, only see the rod from the hand throtle and the choke cable hooked to the carbConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote E Olson Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 4:15pm
OK that little 1 inch hole thats on the opposite side of the distributor and has its view blocked by the loader until I move it back is for setting the timing??? Thats the only one I seeConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 4:46pm
Theres a hole on the bellhousing to see the marks on the flywheel then you loosen the distributor and turn it to adjust. but I wouldnt mess with that odd are it is set fine.    Does the tractor hold RMP?  I mean when you set it half throttle does it speed up or slow down on its own while driving? it should stay a constant rpm, it should "correct" itself. if its running wild high rpm when no load, then slowing to idle under load, then your governor isn't working. that would make it seem to have "low power".
Post Options Post Options   Thanks (0) Thanks(0)   Quote E Olson Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 4:50pm
No i can set the throttle and it will vary the rpm according to the load... If I go downhill it goes faster, up hill it slows down.... So where is the governor supposed to be???
Post Options Post Options   Thanks (0) Thanks(0)   Quote E Olson Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 4:51pm
Can set it at a nice slow idle and it doesn't seem like its too high at WOT to me, just bogs down under a load...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 10:16pm
First off, that engine was never used in a MF.
It looks to be a late 230 or 262. The timing mark will be on front pulley  with a pin pointing toward pulley from front cover if it has aluminum cover.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 10:27pm
You should be able to set that throttle at say 1500 rpm and drive up and down the hills (within reason) and it should hold around the 1500 rpm... If it does not, then chances are, the governor is still a combine gov.
  A combine was set to run at a certain speed and the governor will hold that engine at that set speed which in a combine was wide open throttle. and if you close the trottle down, then you take it off the governor... kinda like manually controlling the carburetor.
 Real old famalls regulers /F-20s/ W30 had a system of the same but most farmers changed them to full governor at any throttle setting.
  Your engine, will have the goveror on the left side ... Here is for a D19 262 engine.. very similer. But you will find that the linkage will probably be a little different on top, and the governor inside also gets changed when making them full governor.
Hope this helps
and while I am at it, I will include the rest of the timing too...
Tom Miller (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Miller (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 10:41pm
Am I understanding that you can change from a Combine gov. to a tractor gov. by changing the internals?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2016 at 10:54pm
Tom Miller, 30 years ago I had contemplated putting a 6 into an old D17 and thought that with enough thought and some alterations, that combine governor could be made into a full govenor... but time and age as taken the solution I had thought that would work away from me.  I should go and check out my 230 engine and refreash the dead brain cells and see if I can remember how I would have done it.
 The 262 engine that I talked of earlier had the whole governor assembly exchanged with a tractor governor, housing, internals and linkage as I recall.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 8:31am
Ted is right the two lower supports are cut off by the foot rest. You want to extend them back to the rear end and build a cradle with a set of 1 inch u bolts to hang them off the rearend. Right now it will be trying to tare itself off the front of the tractor what you want is the lower arms stopping that by pushing up on the rearend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 8:42am
Internally, the governor is pretty much the same. The big difference is the external governor spring tension and how it is applied. Combines are set for full speed (adjusted with an eyebolt) only and are around 2200-2300 RPM. Tractors have linkage that varies the spring pressure to allow for engine speed control (and governor action/response) from the operators seat. Combines also have a different carb throttle shaft and linkage, but that really doesn't affect the tractor part if it is adjusted correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote E Olson Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 8:53am
Thanks all for the info, very helpful ;)  Im gonna move that loader back today, we aren't using it yet but my welder friend says once we get it moved back he can make up some parts to U bolt it to the axle... Im sure I'll be messing with it all day today LOL  I'll get some more pics once I get the hood and covers off....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 9:07am
If you adjust the forward to back position of the loader make sure you leave enough room so it doesn't hit the pump when the cylinders are fully retracted. Ask me how I know that one... There is typically a cover for the pump built out of half inch steal to protect it the covet also joins the two front prices of the loader frame to stiffen then up a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 9:09am
Oh welcome to the forum and the d17 is my fab tractor it will treat you well as long as you take care of it. Mine is the original 2256 4 cylinder gas also serries 1. I grew up with mine and still use it all the time here on the farm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 9:37am
Hey Mack you're right! My old brain cells got confused with my new ones(very few) and after I had kicked the putor to the wall, had a cup of coffee and one (1!) egg I got things lined up. The old Massey that I rebuilt the engine for was a Chrysler industrial. A good engine for the time. Now to 230. I also worked on one, but it was in a Gleaner , and I don't remember the number. All that crap out of the way, if it makes any difference now I agree that your problem has to be with the governor, perhaps in a minor way. I would think they would be a neat little engine and very durable. You'll like it when you get the bugs out. I recommend that you call Orkin. Leon R  Cmo
