onan picture request |
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1888 |
Topic: onan picture requestPosted: 08 Apr 2016 at 6:56pm |
I lost the pictures I took before I pulled my engine. Can I get pictures of how ccka throttle and choke cable are hooked up and routed on top of the engine. Thanks
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4061 |
Posted: 08 Apr 2016 at 11:04pm |
dont know if mine is correct from the factory but i think it is will try to get pic tommorrow
coggonobrien
Posted: 09 Apr 2016 at 11:05am |
that would be awesome Hud, thanks
coggonobrien
Posted: 11 Apr 2016 at 7:03am |
Any luck Hud?
HudCo
Posted: 11 Apr 2016 at 11:17am |
got the pics to my e-mail will work on getting them on here hate to say it but it is a several hour trial and error prosess for my to do these kind of computer things
coggonobrien
Posted: 11 Apr 2016 at 11:42am |
if you want to email me them at coggonobrien@gmail.com i can post them up for other peoples reference
coggonobrien
Posted: 13 Apr 2016 at 7:08am |
Hud, not sure if you got my email or not but I received the pictures. Is it possible to get a higher resolution picture without the air cleaner emailed directly to me? I need to see how the cables connect to the carb
Thanks
HudCo
Posted: 14 Apr 2016 at 11:44am |
i will get some new pictures the next time the sun is out took those with one of those apple smart phones but the pictures never turn out well unless its in full sunlight
coggonobrien
Posted: 14 Apr 2016 at 11:49am |
thanks hud, i'll pm you my cell number so you can just send them direct. Tractor looks pretty mean with duals and a blade
coggonobrien
Posted: 17 Apr 2016 at 7:49pm |
Hud if you can also show me how the 2 cables are anchored to the sheet metal that would be great too.
Thanks!
Les Royer
Joined: 25 Dec 2014 Location: Carson, Iowa Points: 5593 |
Posted: 17 Apr 2016 at 9:22pm |
Actually, I just went through this same ordeal yesterday. But it's on a JOHN DEERE 420. Would that help?
I know what the correct routing is and it would be easier for me to be able to send the pictures to your phone, so PM me if you still need em. I'll be on later tonight. Edited by Les Royer - 17 Apr 2016 at 9:24pm |
I still gots my A/C but it's clear out in the barn now.
Les Royer
Posted: 17 Apr 2016 at 9:36pm |
But it's actually quite simple really. And when I tell ya, yer gonna go well heil. Why couldn't I see that? Cause that's exactly what I did. had to go through about an hour on the dang computer before I found sum pickshure showing the correct routing.
But here's how it goes on my JOHN DEERE 420. The choke cable goes through the firewall. If ya look at the firewall from the front, I got 4 holes left to right. The choke cable goes in the 2nd hole from the right. Now this is looking at it from the front, ok? And thar should be a grommet in the hole. If thars not, you need sumthin around the cable to protect it from thet sharp steel. I just bought the grommet. From thare it goes across the top of the motor and around the dipstick tube and into the cable holding bracket from the front of the tractor. I hope you got the heat sheilding there otherwise yer cable be riding on the muffler. And it ain't gonna last very long if ya leave it that way. The throttle cable goes from the lever around the OUTSIDE of the firewall and into the govenor linkage. so it's positioned between the firewall and the side panel. |
HudCo
Posted: 18 Apr 2016 at 10:22am |
fabbed all the mounts and blade brackets from a little help from all you guys out there
coggonobrien
Posted: 24 Apr 2016 at 5:32pm |
coggonobrien
Posted: 28 Apr 2016 at 6:59am |
