valve adjustment
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Topic: valve adjustment
    Posted: 06 Apr 2016 at 9:16pm
If you are having trouble with you overhead valve Briggs and I suppose others, kicking back or not wanting to turn over like a bad battery, check the valve clearance first. Loose valves on these engine can cause catastrophic disassembly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 9:34pm
It is suppriseing, but if you are 2-3 thousands off on the valves, the motor will come up on compression and STOP.. Acts like a bad battery or weak starter.... Proper valve clearance is a MUST on these for the past 15 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 5:56am
Amazing more people don't know that isn't it? What happens is by getting the adjustment too wide it takes the over lap out of the valves and raises the comp. Briggs has weird valve configuration anyway so that comp. can go wild. But you sure are right they are touchy. Leon R  Cmo
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 11:08pm
bad thing is , is that when they get it to us we adjust the valves  but the starters have been abused so bad that they also need to be rebiult or replaced also
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2016 at 6:00pm
I had a rocker break on mine last year. Got a new one and put it on, making sure the clearance was right for that engine and it started up and died in about 5 seconds. The new rocker was broken. I called a local lawnmower shop and he asked me to bring the head in.
 I took it off and brought it to him and he showed me in 2 seconds what the problem was. The cast guide in an aluminum head came partway out. Enough so it would tip and bind on the valve stem if it wasn't setting perfect. I got a new head and she's been running great ever since.
 A note to remember; EVERY time you finish mowing, use compressed air to clear out any debris on or around the block. If that head gets a bit too hot, the aluminum head can grow faster than the cast iron guide and you got trouble. Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 10:13pm
had a kohler at the shop in a zero turn fins all plugged for a small oil leak in the valve cover i know made the head over heat and the intake rocker stud backed out wich was the reason it was there was they said it would not start      oil leaks on an air cooled engine =short engine life
This page was generated in 1.672 seconds.
