Honda engine in 616-620?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Honda engine in 616-620?
    Posted: 06 Apr 2016 at 6:13pm
If you have a Honda engine in your 616-620 AC tractor, I have a question. What size is the PTO side of engine crankshaft? What size is driveline side?Are they the same as Onan engine? Thanks Tracy
fasstman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fasstman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 7:23pm
My 24 hp was the same as the onan on the clutch side. The drive side had a spacer to adapt to the onan pulley. The spacer and motor mount plate are easy to make. Watch the exhaust. I would wrap it to try to keep heat off the battery. Mine got pretty warm but i did not cook it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 8:58pm
Fasstman, thanks for info. I was hoping someone would have pics of one being installed. Does anybody have a Briggs in one? Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote fasstman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 9:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote fasstman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 9:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote fasstman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 9:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote fasstman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 9:41pm
Greg(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 9:53pm
you can look at Dennis' post in this section to see the install of the Briggs
http://allischalmers.com/forum/forum_posts.asp?TID=115794&KW=DENNIS&PID=940342&title=finally-720-engine-swapmore-pictures-12-12-15#940342
