WD PTO noise
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Topic: WD PTO noise
    Posted: 08 May 2010 at 2:03pm
I hooked up my rototiller to the WD and as the tiller dug in I got loud knocking noise in what I think is the PTO box under the transmission. What's going on? I shut it down after a couple minutes. Did not get worse nor better until I shut off the PTO..then all quiet.
This PTO really hasn't been worked that hard..if at all. I've known this tractor since 1952.
Life is short...Make haste to be kind
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 2:34pm
I would plan on draining the tranny some time and drop the PTO box to have a look at the gears and bearings. It could be a bad bearing or maybe a chipped tooth on a gear???
