190xt
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt
    Posted: 04 Apr 2016 at 8:04am
Anyone have a PDF manual?
Need to drain and refill the transmission. How much oil for just that reservoir?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 8:58am
There are two drain plugs. One directly behind the battery box and the other to the left of the PTO shaft and forward four inches. The amount it takes depends upon which dipstick is being used. This is related to 2-pinion or four pinion differentials, which is a 50/50 deal....it either has it or it doesn't. Go by the dipstick....8 to 10 gallons serves my memory. The hydraulic system(two more drain plugs) takes 5 gallons plus more for a filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:13am
OK thank you.
Seems we had some water get in the transmission via the shifter (missing the little o-ring seal). This is the right side dipstick (At your right foot)
The Left side dipstick does not show any contamination.
This is a Series II per serial, so a 2 Pinion.
I read on Tractordata that the transmission hold 38 qts but I didn't know it that was just the tranny or combo of the tranny/PD
Charlie
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:33am
Cooling capacity---18 quarts
Crankcase Oil------8-12 quarts
Power director
& hydraulic system-24-36 quarts
Transmission-------27-32 quarts
Final drive-each---8 quarts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:35am
Thanks Rick
That is a lot of oil!
Charlie
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:39am
Yes, it is, Charlie! LOL! That's right out of an AC manual.   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:43am
I saw a note that after serial 23000, it gets 38 qts instead of 32.
At this serial was a transmission fix. What was this? or what was fixed/corrected at the factory?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:45am
Also since the oil is milky, what is the best way to flush? I hate to put $100 in oil in it and then it again a few weeks later since all the water didn't drain out.
Charlie
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 10:05am
Charlie, whenever I flush something I have always used kerosene. Flushes clean and drains real good. Hope it doesn't take a double dose. Leon R  Cmo
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 10:17am
What Leon said or I use diesel fuel. Let it drain real good and then you're only putting oil in it once. I'm not aware of the update on the tranny on the 190 XT, sorry. Sounds like a lot more oil in the tranny though! LOL! Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 11:14am
You cannot depend on the serial number to determine 2-pinion or 4-pinion. Many thousands of pre-23001 tractors had 4-pinions installed after a failure and then got a different dipstick, raising the oil level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 11:18am
Ah, than makes sense
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 11:29am
How much does the starter weight and each slab weight weigh?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 12:21pm
250 and 75 each.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 12:43pm
I really appreciate all the help
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 7:17pm
Drain plugs I found
Under the battery box
Same area.
Rear by the PTO housing
Each side has this
Charlie
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:06pm
The one you have pictured same area isn't a drain. Look foward at the bottom of the hydraulic screen.
Edited by Dakota Dave - 04 Apr 2016 at 9:10pm
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:35pm
The last picture is the bull gears / final drives. you have to fill them up on each side they have a separate compartment.
Edited by DanWi - 04 Apr 2016 at 9:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 6:14am
I was mainly looking at the rear end to see if it is a 4 pinion or not.
I didn't look at the PD/Hyd portion for a drain.
Does that give enough info to determine if it was changed to 4 pinion?
Also on the rear right side is some stamped numbers (Not cast) to the right of the PTO housing. Do these relate to anything?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 6:19am
This was not correct. Series III was serial 2300
The transmission "Fix" was in 1966. Still not sure what that was.
Charlie
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 7:41am
Charlie, those stamped numbers are likely the ones that are used for setting the snap ring thickness in the rear end for the pinion depth dimension.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 8:05am
The fix consisted of a shift lever new breather, Oring and dipstick that's 1" shorter.there are no external clues weather it's been changed to a 4 pinion or not. If you want to know you need to pull the PTO housing and look. Don't let the engagement coupling drop or you'll cause lots more work. You could just run it and not worry about it. Lots of 2 pinion tractors are still working without a problem. If your tractor has been overweighted and turned up you either have it or your going to need the 4 pinion upgrade. But that's not the only part that breaks when a tractor is pushing more power than it was designed for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 8:15am
OK, thanks for the info.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 8:21am
To bad they didn't stamp an X or something at the end of the serial to indicate the change.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 9:09am
The raised oil level dipstick tip was cut off at a 45 degree angle. The old dipstick was square cut.
