WD45 oil bath air filter screen replacement
Le Renard Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Le Renard Farm Quote  Post ReplyReply Direct Link To This Post Topic: WD45 oil bath air filter screen replacement
    Posted: 02 Apr 2016 at 7:58pm
Could you folks help me with my new 1956WD45? I am going to replace the screens in the oil bath air filter but am not sure how to get them out. Does the ring just under the screens come out? I tried but it didn't want to move so I stopped before I broke it.It is a United oil bath filter. Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:01pm
You have to break thru several spot welds and then pull the ring free. There are three rolled up segments of wire mesh. I always unrolled each one and washed them out in solvent and reused them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:04pm
Agreed, Once you are able to get them out, you should be able to clean and reuse them.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:21pm
On one oil bath I took it off the tractor plugged the two air holes and filled it with diesel fuel soaked it for a day drained it out then tapped the assembly on the ground and blew it out with compressed air.   I got it really clean. That one went into a different tractor and getting the screens out would have broken the housing for good in that case. On my d17 I did just break the spot welds. Soaking then in diesel works great to clean the screens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 9:27pm
Role them up, soak them in gas then set them on fire. After they cool, unroll them, knock the soot out and reuse them.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 9:34pm
Well, I spent a lot of time on the last one I did (corn picker fuzz) and this pyro-technique thing sounds like a really good idea !!!!
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 3:07am
I put the whole assembly in the parts washer for a few days then rinsed it out good before draining and blowing air through it. last thing I did was spray a can of WD40 into it to be sure it wouldn't rust.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Le Renard Farm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 3:56am
Thanks everyone! I think cleaning of the screens on my tractor has never been done. The stuff I pulled from the intake tube was half an inch thick. I like fire and future service will probably include flames.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Le Renard Farm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 4:12am
Follow up question. Has anyone tried running the oil for the filter through a paper coffee filter to re-use? Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 5:21am
Just save used motor oil and put it in there you won't change it enough in a year to use up your used motor oil.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 5:37am
It doesn't hold much new oil. Used oil contains acids that may rust components. Change the oil every 10 hours or so of use. If you can't do that then adapt a dry air cleaner to it and set the oil bath on a shelf.
Wink
I am a Russian Bot
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2016 at 6:16am
I think 10 hours is a little extreme unless its really dusty. I can look at mine in 20 hours and it looks almost new. I would say. Change when you change oil. Chen it some other times to make sure it's not to dirty. You know those old oil quarts that collect around a farm with torn off labels so your not sure what weight they are?? That's the oil I use in the bath
