Need Help to install spring on Hydraulic assembly
George Davenport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Topic: Need Help to install spring on Hydraulic assembly
    Posted: 01 Apr 2016 at 7:21pm
I need some advice on installing the return control lever spring on my 52 B hydraulic assembly.  I have the spring which appears to need  compressing before installing onto the shaft.  How is a good way to do this?  I would like to do this while it is mounted on the transmission if possible.  All ideas will be appreciated.
Life is what happens while you are making plans for the future
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 11:56am
BUMP
This page was generated in 0.336 seconds.
