sun star
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: sun star
    Posted: 31 Mar 2016 at 12:07pm
does the sunstar 20 horse with kohler magnum have an   in line full filter ?
The issue is had starting after sitting, now more than a week or so  and it takes gas down the  carb to get it going.  any other ideas as to cause ?
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2016 at 5:19pm
make sure fuel pump isnt leaking into crankcase
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 9:06pm
Add some high powered gas treatment that gets rid of varnish, water, dirt etc. get running long enough to get plenty all thru. the gas delivery system and forget for a day. Try it and see what happens. If you can get it to stay running, with a spray bottle spray water into the carb. until it affects how it's running a little bit. You can put about a half pint thru. it and this will steam out the carbon and make it run better. Try not to kill it with too much water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 8:48am
will try
thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 12:48pm
Tractorman, did the water help? Leon R  Cmo
19856020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19856020 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 6:10pm
check if fuel pump is bad
716 917 918 1920 d17 6080
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 8:10pm
will it start back up  after you have had it running a while
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 8:44am
have not tried  water yet
Put the gumout regane about a quarter bottle in the tank and ran it a while then parked it for 2/3 days. took it out yesterday for about a half hour , so far seems to  run better, smoother more responsive.   also  when i tried the choke i noticed i was able to pull it out about an inch farther than i had been, just more muscle ( i try not to force things )  now it starts right up with out a lot of cranking.
will try the water later.
thanks to all for helping, thats what is great about this forum!
This page was generated in 0.184 seconds.
