Allis M pulling Bros Compactor: Compaction ?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Allis M pulling Bros Compactor: Compaction ?
    Posted: 29 Mar 2016 at 12:00pm
Hi guys-Enjoy the picture. Questions for you guys...
When I do compaction work, how do I know I have compacted enough. What is the test?
When you guys do compaction, do you add water?
Edited by nowaktj - 29 Mar 2016 at 12:01pm
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2016 at 12:23pm
yes water helps but its easier to work with the dirt when it has moisture in it.  also you want to limit how thick your dirt is when compacting or it wont compact as well.  we try to keep the material 6-8 inches at a time when we build pond dams,   to much at a time and you can get it compacted well.
i dont know what you are building but you could drive a fence post into it and get a feel compared to normal ground
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2016 at 12:32am
That sure is a nice looking machine!
Allis Express participant
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 1:16am
x2
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 8:29pm
We add some water and mix well with motorgrader or something with an angle blade in 6" layers. Dry dirt won't bond together [as others have said] Be careful adding water! Its usually easier to add a little more than to try to dry it out.
 We "proof-test" with a well loaded dump truck driven across the fill.The depth of the ruts will tell you roughly how much compaction you have already.
 Final tests are with nuclear densitometer , depending on type of project and what the customer wants .
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
This page was generated in 0.371 seconds.
