Tree Puller or post puller
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: Tree Puller or post puller
    Posted: 25 Mar 2016 at 12:58pm
Sons tree puller or post puller . For skid loaders or modified for 3 point tractors .
[TUBE]http://youtu.be/rNv0cyzc90k[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 1:00pm
If someone needs a testimonial on this - Shameless might chime in and say how good it works .
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 5:05am
Coke
Not going to sell any machinery but another post puller from the BAR end of ranching (busted a**^ ranch).
A hefty tree fork about 3 feet long with a slot chainsawed in the single end to locate a chain and the fork ends trimmed to a blunt  flat  point.
Stand with the fork end down against the post at about 45 degrees, with a chain from the base of the post over the single end of the fork and on to your 4wd and pull.
Doesn't always work first time but with some adjustments for conditions does work.  And you don't have to double shuffle machinery.
Known here as "The Tooth Puller"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 2:29pm
Galen tried several designs for tree puller - has a couple other designs but didn't do as good a job .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2016 at 9:33pm
Galen just shipped a buckthorn puller out to Maryland today - a order over internet video of the unit so - loaded onto Fed X truck and on it's way .
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2016 at 6:21pm
Buddy of mine got one of Galen's in a partnership deal with me last fall, but the ground froze up right about the time we got it, so we haven't tried it out yet. Darrel
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 1:30am
i'm still using mine I got from Galen, mines a 3-pt model, as I don't have a skid loader. I hook it to the 7010. I normally pull 5-6 inch on down size trees, I did pull one 9 inch dead cedar with it, it worked fine. so far I've pulled about 1500 trees with mine, and it doesn't even look used! I keep the slider greased well. there has been a lot of people in my area look at mine and like how heavy it's built, I gave them all Galens phone number! I should start a dealership for them down here! all I see around here are those hyd "v" shaped pullers that mount on skid steers, and see a lot of them on auctions all bent to chit! i'll be going out with mine again this spring to pull more! you can also stack/pile the pulled trees with it, I've got piles all over on the pulled trees I've done so far! had one dude stop on the road and watch while I was carrying a 30 ft tall tree to the pile one day! Darrell...you'll like yours too when you use it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 1:34am
Coke....post that vid on the farm machinery site too
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 10:45am
He is looking for dealers for the units - has a dealer here in MN and has a special system on discount for him -
 Also has his product liability insurance and has couple units now at A machinery dealer in area but wants to expand
 Good time right now as slow time as snow plow mfg was slow - right now shop is down to building inventory and sales are slow .
