Tire pressure
AC puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Topic: Tire pressure
    Posted: 23 Mar 2016 at 10:34am
Pulling for first time this year with 13.6 38's instead of my 28's on a wd45. On a hard track what pressure seams to work the best on a hard clay track?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 10:38am
Depends on rim width and weight and cut or non-cut......8 to 10 psi is my guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 10:56am
12 inch rim. Half tread. Non cut. 4500 and 5500 class. 3 mph
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 11:11am
I had good luck with 10 psi last year with my 13.6x38's.
They are a bit faster than 28's though
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 11:33am
At those weights, probably not less than 10.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 12:54pm
I run 10 in my full cut 15.5x38 on a hard track
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 2:11pm
Tire pressure for pulling tires is about as loaded a questing as to what type of women one prefers or who builds the best P/U, you get as many answers as people you ask. In general if you have power and need traction go lower until the center of the tread quits biting and raises up (When you look back at your tracks after unhooking) When your lacking power raise the pressure to loose some grip.  A good start for bias ply tires is 1 PSI per 1000 pounds of tractor weight, then adjust as performance dictates. You want the tires to squat a little but not to buckle severely.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 9:00am
So you're saying 3.5 psi. of in the 3500 lb. class and 4 psi in the 4000 lb. ?
I have run 6 lbs. in the 3500 (on a soft track) and thought I they were way too soft.
Edited by WF owner - 25 Mar 2016 at 9:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 10:30am
That age old theory of 1 psi per 1,000 pounds of weight works pretty well on a 24.5 or 30.5 x 32 tire.....nothing else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 2:13pm
That has worked for me in more than 40 years of pulling with everything from multi engine modifieds, Superstocks and the small antiques I've pulled. As I mentioned depending on conditions of the day and the power your tractor has (Or lack of) and adjustment from that may be called for. Also a low ply tire on an over wide rim needs a tad more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2016 at 5:03pm
I have no argument with the 1 psi per 1,000 lbs with the 24.5 or 30.5 x 32 tires......I'm just sayin that ain't the way to go with a 15.5 x 38 tire on a 3500 pound antique tractor. If it works for you great....I'd never advise someone to run that low(3 1/2 psi).
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 4:35am
at 3.5 psi you will  roll the tire off on tracks in central ILL
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 5:51am
As I first stated: asking a question about tractor pulling will get you more answers than people you ask. I started pulling in the later part of the 60s and have had a winning record in every type of pulling I've ever been involved with. I use that as a baseline to get started with a combination I have no experience with, rarely do I vary far from that.  When I answer questions about what I'm doing pulling and how I win so much, nobody believes me anyway. Lower pressures can't be used if the rim is too wide for the tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2016 at 8:28am
I have 16.9 x 28 (14" rims) on my WD-45. I will try anything once. I am going to try 4 psi in the 3500 and 4000 lb. classes and see how it goes.
TennMatt1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TennMatt1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 4:57am
AC puller I'm just curious as to how you pulled with 38's compared to 28's.I don't know how much you got in your engine to pull 5500 lb cause I've never seen one on 38's pull it. Like I said curious because I'm wanting 38's myself.
1954 WD45
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2016 at 11:53am
Not sure about AC pullers tractor but I know my tractor pulls way better with the 38s than it ever did before and I run 4000-5500 most of the time and have hooked it in a 6500 lb class before and I had it weighed 6200-6300 lbs but the 6500 and 5500 I hook in are low gear classes but I've never powered it out in those classes with the current set up
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 5:06pm
Pulled 4 times. 4000 open,5000 open, no rpm limit. Pull my cheater rod. And 4500& 5500 3mph. Have 23degree firestones about half tread. Plain 4-1/8 overbore and headwork. Don't think I did any better than my 28's. But need to play with weights. Little different animal now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 5:08pm
Running 10 psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 8:57pm
38's will almost always out distance a 28 of the same width if they are equal in wear/brand/sharpness. You're talking about "uncut" tires and that isn't very fair. Your 28's may simply have been sharper than the 38's. You can't compare a 28 Firestone F-151 to a junk Goodyear 38.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 9:04pm
My 28's are brand new firestone field and roads. So ya your probably right. Pull against another 45 with better 38's tread wise and he beats me by 20 or so feet every time. So are newer more tread tires better than half hard tread then?
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 9:44pm
How wide of 38'sdo you use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 6:36am
14.9s
Robacpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2016 at 8:52pm
I run 15.5 x 38 on my 37 wc. I run 10 psi. I pull any where from 3800 to 6000 lb. Class. I have a 400 cube motor running 110 hp. Never out of power but hard to keep front down on good clay tracks. 2300rpms at around 4 mph.
180Puller View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180Puller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2016 at 9:04pm
Yesterday I pulled the 5500-6000-6500 5 MPH classes...I ran a little over 8 lbs in 18.4x38 Firestones on 20" rims....I might have gotten by with just a little less..
This page was generated in 0.110 seconds.
