WD puller pics
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: WD puller pics
    Posted: 22 Mar 2016 at 8:51am
Thought I would post some pics of my WD45 (1956) that I use in stock class (3 mph)
Club restricts use of 38's on AC's, so I have 14.9x28's so I can pull 3500lb and up.
I use rear, mid and front weight locations. Front I can use suitcase or the stack weights as needed
I use a cat 0 link adjuster for height (20"). Attachment location is legal, although I would like it lower.
D19 carb for max air/fuel flow. Requires a Fuel pump to feed it which I have located under the tank support
"Z" Code Gleaner E motor. Frame is notched a bit to make it fit. You also have to tweek the oil flow tube as it hits the steering shaft.
Electronic Ignition set up for 12v neg. ground.
Edited by Charlie175 - 22 Mar 2016 at 8:54am
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 8:54am
Steering shaft tweek
Charlie
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 6:24pm
Nice tractor!
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 8:05pm
Why are you using the WD governor set up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2016 at 8:33pm
right now it works and it is responsive. I get 2200 rpm which is the most I want to go.
Charlie
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 9:05am
nice looking tractor sure would like to have rear firestones on my my wd they look pretty tall without fenders
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2016 at 9:16am
I can't imagine 13.6's on these tractors, they seem to be made for 14.9's.
I had 16.9x28's on it but I couldn't run it in 3500.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2016 at 8:47am
my wd has 13,6 and my wd45 has 14-9 big differance when sitting side by side
