depressed
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Topic: depressed
    Posted: 07 May 2010 at 3:18am
i started my d19 for the first time for the year and the rearend wants to keep locking up anyone know what would cause this after just sitting all winter worked great last year. confused
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 5:54am
The brakes are know for locking up. The acuation balls get dirt and brake dust on them. If you back up does the axle turn freely?
1968 D15D,1962 D19D
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 6:27am
Don's on the right track...I've had that same trouble in the past,but only with the one D19 that sits outside all the time. I believe the dampness and moisture has a lot to do with this,as well as the dirt/dust problem. Usually,after we use it for a short time,it straightens out and works fine. This is just the experience that I've had with mine.  Rick
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 7:22am
Hey Rick, I'm going to pickup are new toys today.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 1:17am
i want to think everyone that has applied it must have been the brakes after i hooked the plow up and used it all day it hasnt done it again. but i was sure nervous and it will be parked under cover from now on thanks again.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 2:45am
park it inside on your wife's side of the garage!!
