WD45 - Front Axel has the Shakes...
Hlone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hlone Quote  Post ReplyReply Direct Link To This Post Topic: WD45 - Front Axel has the Shakes...
    Posted: 06 May 2010 at 10:34pm
Just got a WD45 that has the shakes when I take it out on the road in 3rd or 4th gear.  She will stay in a straight line, but I wouldn't want to hit a bump or make a sharp turn :)
Where do I start digging in to make it tighter?  The wheels are bolted on tight and the front wheel bearings are good (one side has a little play and the other side is good).
Thanks for your help!!
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 10:36pm
IS the wheel itself straight and true?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hlone Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 10:42pm
Wheels seem to be straight and don't have any rim bends.  I made sure all of the lugs were on tight.
The front axel will "flap" back and forth like a flag in the wind when getting up to higher speed.  There is play in the steering linkage, nothing horrible.  Maybe about 5 degrees of play while turning back and forth.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 10:57pm
Look at the u-joint and stabilizer on the right side of engine they get worn. and then look at the gears in the front end bolster.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 8:50am
Tie rod and drag link ends?
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 9:04am
Check toe in.
Ohio WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ohio WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 12:34pm
I assume you have narrow front.  The mailman and I were talking about this very thing last Saturday.  He has 2 WD's and I have a WD 45.  He said one of his WD's had this problem, and he tightened the set screw between the front wheels.  You need to loosen the big nut first, and then tighten it after the set screw is tightened.  You may need to take a tire off.  It is also a good idea to check that U-joint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hlone Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 9:14pm
Thanks for the Words of experience.  I will check everything out and post and update.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 11:09am
It only takes a little slop or lash to make a narrow front do it.  My WC has a lot of play and it seems a lot worse after it sits a while, I think the tires develop a flat spot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hlone Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 9:03pm
I finally got the Shakes cured!
We took the front end off and pulled out one of the shims on the steering gear housing.  We also replaced the coil pins in the steering knuckle as they were worn adding to the steering slop.
After getting everyting back to gether she drove like a true lady and I am quite happy!
Next task to get the lights working again...
1953 WD45
This page was generated in 0.103 seconds.
