What's this for?
Stu ECWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stu ECWI Quote  Post ReplyReply Direct Link To This Post Topic: What's this for?
    Posted: 06 May 2010 at 6:01pm
After seeing the identification of Jeff's picker bracket, I remembered this one.  Does anybody know?  It came with a bunch of WC stuff.  It does have orange paint on the back, and the moving arm.  Thanks, Stu
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 8:15pm
OK, let's give it a try.  Really have to test my memory for this.
I think this is an attachment for the power lift that moves the direction of the lift so that it can lift in the proper direction.  I think this attaches to the power lift for lifting the cultivator.  This is an older power lift adapter.  The two square headed bolts fit on the WC frame under the power lift.  Again if I recall rightly the newer one had more of a channel iron type of base.
Hope someone can confirm cause I'm kind of not too sure on this one.  .
Good Luck!
Bill Long
