WD45 diesel front axle/bolster
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: WD45 diesel front axle/bolster
    Posted: 06 May 2010 at 3:34pm
I am looking to build a WD45 with a 230 gas engine (out of a combine), I guess a WD55 technically I think thats what they called them anyway.  There seems two be two bolsters on WD/WD45 tractors.  One has a "set in" on the side toward the motor while the other does not.  Are the ones with the "set in" made after the diesels came out to give more room for the diesel engine?  These are narrow front ends by the way.  Are the wide fronts set up the same?
Thanks
Adam
Edited by Sandknob - 06 May 2010 at 3:36pm
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 7:39pm
I have been informed that the WD-45 Gas ans diesel WF Bolsters are the same. Have been cleaning up a diesel bolster last few day's, do not have a gas WF bolster here to compare.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 8:57pm
what i have been told is that the 4 bolt wide front end was introduced at the same time as the diesel 45 and was designed to accommodate the diesel. Chris/CT is correct in that the 4 bolt design was also used in all other 45s from that point on just because it was stronger than the 3 bolt of WDs and early 45s. but the earlier 3 bolt bolster wouldn't work with a 230
Edited by Bill_MN - 06 May 2010 at 9:00pm
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 9:04pm
the 45-d4 bolt fwd axel pivot are the same on the gas and the diesel.the difference is the aft pivot,which is a wishbone shape to clear the oil pan.i have a pattern for the aft pivot if you need it...
