Can anyone give me some information
Garrett D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett D17 Quote  Post ReplyReply Direct Link To This Post Topic: Can anyone give me some information
    Posted: 11 Mar 2016 at 11:36pm
I purchased this d17 in the fall and I noticed that it has 38inch rubber and seems to be a high crop. It is a gas engine and has a narrow front end with power steering. If anyone could help me learn what this is I would appreciate it. I can't post a picture because the file is too large but I can email you pictures if wanted.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 6:05am
What you likely have is a high clearance D-17. Is it dual narrow front wheels or single wheel? A high crop D-17 is real tall. You can email pictures and I can likely tell you more. there are four series of D-17's.  Email address is in my profile. Click on my name. Welcome to this forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett D17 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 7:58am
I can't figure out how to get to your profile. I'm new to this
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 8:51am
Click on my name and then member profile. email is on that page.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett D17 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 9:14am
I sent you an email with a picture
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett D17 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 10:18am
http://s1172.photobucket.com/user/GarrettD17/library/Mobile%20Uploads    This is my d17. Thanks for future input and information
bikley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bikley Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 10:25am
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 10:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 10:34am
Decent looking tractor.  Looks to be a 1959.  Did the narrow fronts have braces going back to the torque tube?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett D17 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 10:57am
59 sounds about right. I looked up the serial number but wasn't sure if it was 57-59. It's defiantly series I. And those braces just bolt to the bottom of the bell housing below the fly wheel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett D17 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 10:58am
I don't think a standard narrow front had any braces
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 1:09pm
The grill makes me think you'll find your serial number falls in this range:
Series I  -  Black Bar grill
1959     24001 – 28199
1960     28200 – 31625
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett D17 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 2:06pm
I called my dad and he checked. It's a 59
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 3:28pm
the tars are backwards lol. i like the narrow  front end
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett D17 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2016 at 3:42pm
That's because we swapped the rims around. The were set way ouT and flipped around
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2016 at 9:05pm
Can you post some closeup pictures of the front end. Something going on there that I haven't seen before. It still has the brackets for the front mount cultivators.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2016 at 6:28am
arent those wheels spin-outs?
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2016 at 7:45am
Look at the high crop spacer under the front end...most original high crops have some sort of spacer in the spindles or under the front..Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2016 at 2:52pm
There is a peice called the bearing holder that bolts onto the main front casting if you have a single front wheel on a D series tractor. The single front yoke is the same as for the WD-45. Since the 'spacer' appears to be similar to a bearing holder, I'm wondering if they are using the narrow front conversion that the WD-45's used when you mounted a corn picker on a wide front tractor. In that case the whole pedestal turns with the wheels. It would bolt together. The standard D series narrow front bolts directly to the main casting with the pedestal stationary and a shaft steers the wheels. I have some of each.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2016 at 5:14pm
congratulations on getting a somewhat unusual tractor.
