Allis Chalmers TL 14 wheel loader
JWS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWS Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers TL 14 wheel loader
    Posted: 10 Mar 2016 at 10:04pm
Hello from a first time poster. As the title says, I just purchased an AC TL 14 Tracto Loader. I have a few questions. I have gotten it so I can use it and it runs with good power. But I do not know what all of the levers in the cab do. I have figured out the brakes aren't real good! I know the forward, reverse and neutral lever on the left. The two levers on the right run the bucket and arms. Behind them is a lever that I don't know what it does, I think it is the two or four wheel drive selector but I don't know for sure and don't know which position dictates what.
By my right ankle is a lever that seems like it should turn like the hands on a clock.
Also the steering seems sluggish and really slow to respond.
Any and all help would be appreciated. This weekend I will try to get some pictures and have my daughter help me get them on the computer and post them here.
Really appreciate any and all help. Thank you all for this forum and any help you can provide.
Jon
I am so far behind, I think I am in first place!
JWS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2016 at 5:48am
Is it possible I have posted this in the wrong section? 26 people have looked at this and no comments?
Jon
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2016 at 6:18am
First off, welcome to the forum. You have the right spot, just might take a little time for the right person to see your post. There is a wealth of knowledge here, so someone will be along that can probably answer all your questions and possibly be able to tell you where to find manuals for your loader.
JWS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2016 at 10:23am
Thank you TruckerFarmer, appreciate the information.  Patience really hasn't been one of my virtues. Confused
Jon
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2016 at 10:46am
problem is there are just not many of those loaders out there and there are a couple different series.   and pictures always help
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2016 at 2:12pm
JWS, glad to have you on board! It may take a little while to get an answer, but you have definitely posted in the right place. Traffic is a little slow over here on the construction equipment side of the forum, but give it a little time. Posting some pictures will be an attention getter. Darrel
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2016 at 6:04pm
http://www.minnpar.com/manuals.asp
this may be of some help
    B:-)     Dnoym
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2016 at 12:07am
The lever by your right ankle should be the brake cut out valve. In one position (down I believe) the transmission disengages as soon as you press the brake pedal, in the other position the transmission stays engaged while the brakes are applied. The feature with the transmission cutting out is so that as you come up to a truck let's say, to dump your bucket you need to temporarily rev the engine to quickly lift the bucket without manually taking it out of gear. The extra lever close to the bucket controls could be a third valve for a grapple etc. A picture might tell. I've never heard of being able to select 2 or 4 wheel drive. If you can follow any plumbing or hoses you might find out where they go. Regarding the sluggish steering there is a chance that the machine has a separate hydraulic pump for the power steering in which case very likely the pump is tired and the pressure is low, if it has a separate oil reservoir check if the fluid is low. If you follow the lines from the power steering you might see if they lead to a smaller pump somewhere.
