CASE-IH fuel problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: CASE-IH fuel problem
    Posted: 10 Mar 2016 at 12:41pm
Friend has a CASE-IH about 25 years old. Front wheel assist , 6 cyl diesel, maybe 80 HP and I think it is a 4230 ???
In the past few months the tractor seems to loose prime to the fuel pump after setting for a  few days. This is a manual shut off tractor. You pull up on a knob to shut off the fuel. I can see the cable and link on the fuel pump move open and close. I don't think the shut off is the problem, but im not sure. It has a plunger primer pump mounted on the tractor frame by the fuel filters. If I pump it 20 times, it will eventually start back up........ is there a check valve leaking off, or does the hand priming overpower a stuck valve...... or ? ......... im open for ideas on where to start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 12:53pm
Start by looking to debris screens in the fuel tank outlet, then for hoses or tubing that may have a slight pinhole that will not always weep but will suck air like a braided hydraulic hose.  Next look at that priming pump for it may leak around the packing on the plunger and while may re-prime the system could suck air when running.  My 180D had a outlet screen in the sediment bowl, was darn near locked tight with crud.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 5:27pm
I will check the hoses for cracks Dave... im not sure about the pluggage as it runs fine once it starts up. Just seems to run out of fuel after setting a few days. Once primed, it runs fine... I will check for "wetness" on the lines and fittings......... I was hoping there was some "secret" specific to these old CASE-IH motors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 7:33pm
Should be old standard American Bosch or Roosa system fuel delivery, if it is a Stanadyne/Roosa Master then look for the pump to be failing otherwise welcome to low sulfur diesel issues as we all get to play with.
This page was generated in 0.201 seconds.
