Allis H3/HD3 Sprocket Capscrew
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: Allis H3/HD3 Sprocket Capscrew
    Posted: 09 Mar 2016 at 6:43pm
Guys:  Need to replace a few capscrews that hold the sprocket in place.  The part numbers is 241032. The number for the capscrew in later parts books changes that showed a longer capscrew that extended through the sprocket and axle flange terminated by a nut.
The original capscrews have a thick head and I believe they are 5/8" x18 thread - Sandy Lake says no stock.
Does anyone have a cross reference to a Dorman wheel stud that might interchange with the Allis Capscrew.   Was thinking Caterpillar might have something as well.
Any ideas would be appreciated.
Thanks...Orangeman
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2016 at 10:03pm
Cat nut and bolt hardware is as good as you can get,and the same price or cheaper a lot of times.They have a on line catalog that I have got into to get part numbers of bolts so not hard to do. The catalog is called " One Safe Source " don't remember if that is online name as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 4:20am
Found the Catalog - excellent information and Thank-You!
This page was generated in 0.085 seconds.
