UM Engine
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: UM Engine
    Posted: 05 Mar 2016 at 9:44pm
Does any have or know of a running UM engine that could be for sale? I found an "M". It looks good, but, it has set outside with NOTHING over the exhaust pipe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2016 at 9:45am
Try Norm Meinert 815-238-4506
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2016 at 10:21am
I would pull the head and have a look before swapping engines. You might find it's rebuildable. We got an old Wallis a while ago that had set for years with no head and no cover on the engine.  It was only lightly stuck. The engine was so worn that any water that had got in had run past the pistons and into the crank case.
