What's the difference
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Topic: What's the difference
    Posted: 03 Mar 2016 at 5:07pm
What's the difference between an allis d14 and the allis d15? I can find all kinds of parts for the 15 but struggling to find anything for the 14. I haven't given up on the guy that offered me his used fenders. I just hate to buy that far away the shipping will eat up my budget
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 6:03pm
If your talking sheet metal the fenders on the D14,D15 series I and II are the same size. I never put a tape measure on mine but I think the frames a little wider on the D15.
the D14 and D15 series I both had the 149 CI engines, but the d15 had a higher compression ratio: 7.75 to 1 and the rated engine RPM was increased to 2000 instead of 1650.
I'm really on sure on the transmissions.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 7:30pm
A D-14 and D-15 Series l do not share any sheet metal except for the fenders and the panels under the gas tank. D-15 l and D-15 ll do not share hood panels and the fenders on the Series ll has holes for headlights and the rad shell does not. The D-14 transmission  is the same as the D-15.  Part numbers for some of the gears in the D-14 are updated to the D-15 part number. I have a D-15 Series l diesel with a D-14 transmission.
Edited by Calvin Schmidt - 04 Mar 2016 at 8:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 8:11pm
Thanks guys that helps a lot
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 10:14am
I don't know if this would interest you but I have a D14 that is complete but stuck I would sell, it is not perfect but maybe you could use for parts.
