just about finished!
 Rating: Topic Rating: 2 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Topic: just about finished!
    Posted: 01 Mar 2016 at 1:57pm
Hello guys, just wanted to share the 200 narrow front project I have been working on. It has been quite a task! Way more to take into consideration before I started! HAHA. To share a little bit about the project. I started with a factory open station late model 1974 200. I have collected the parts to make this work. The "zipper" front is out of a series 3 190xt. I interchanged the front bolster to make this happen the front pulley on and water pump needed to be changed to be as a 190xt. Simply because of the clearance and different radiator placement from a 200 to 190xt. Next the air filter housing and oil fill tube for the front needs to be relocated to work with each other. And the tricky part is getting the radiator to fit between everything! ha-ha. With the factory narrow front the oil pan gets in the way so the largest size tires that I could have on the front were 9.5l-14 tires. it sat very low in the front this way. So since the 200 sits roughly 2.5 inches higher in the front than a 190xt to begin with I made a space plate to go in between to accomplish the proper 200 front end height along with getting a little more clearance. The next issue I ran into was using an 11L-15 tire and not hitting the oil pan or a front weight so. To accomplish this I used a D19 narrow front bolster. They are the exact same height and width as the 190xt but in relation to the 190xt narrow front the axle on the pedestal sits roughly 1.25 inches further forward. With the modification of my 2 inch spacer I made this possible. Once this was done the rest of the tractor was just a standard restoration process! I did put custom steps and all LED lighting on the tractor since nothing is proper on the tractor any more already! All new gauges including installing an oil pressure gauge. I am getting a little long winded! Just wanted to share!
Andy
Andrew Gubbels
Gubbels Restoration
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 2:01pm
WOW
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 2:02pm
Looking good andy! what a project!
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 2:07pm
That is absolutely gorgeous!! Wow! You are talented!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 2:11pm
Yes, WOW, that will make people scratch their head.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 2:12pm
You do very nice work Andy !!   I'm assuming that one is for your collection.
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 2:33pm
Absolutely Beautiful !!!! Belongs on a calender
Cowboy UP
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 2:51pm
good looking machine!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 3:02pm
PURDY!
Greg Kroeker
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 3:20pm
WOW.JUST SIMPLY WOW.AWESOME LOOKIN TRACTOR.IV'E ALLWAYS LOVED THE NARROW FRONT END ON THE BIGGER TRACTORS.SUPER JOB I WANT ONE!!!CALENDAR MATERIAL FOR SURE!!!
Edited by ac45dave - 01 Mar 2016 at 3:23pm
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 3:26pm
The correct police will have you behind bars by sundown...lol. Looks great though!!!
Matt Folkers
FOLKERS RESTORATION
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 3:42pm
 Thumbs Up Thumbs Up
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 4:03pm
Screw the correct police, that is a beautiful tractor, I don't care what you say!
Allis Express participant
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 5:02pm
That's amazing. Looks GREAT!
KY poorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY poorboy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 5:29pm
That is one AWESOME looking tractor!!!! I don't care what the purist have to say, it's just cool!!
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 5:46pm
It's AWSOME Andy.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 5:54pm
If I didn't already know that 200's were never narrow front, I would not know the difference by looking at that! It looks like it came from factory that way. Very good job, it looks great!!!
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 6:00pm
Simply gorgeous!  Nice work and attention to detail.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 6:53pm
SWEET WORK
FIVE STAR + JOB
DAN
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 8:46pm
last pic belongs on a calendar .
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 8:52pm
Looks terrific!
Life is tough,but it's tougher when you're stupid. - John Wayne
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 8:58pm
Great Job Andrew !!!  It legitimizes my 220 XT.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 8:58pm
Had to put a bib on. That is one sharp looking 200.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 9:11pm
Andy,  That is one GREAT LOOKING TRACTOR!
Have to say I still like the narrow front ends.  I know they are not in the rage now but they look good.
Andy,  Did I see you on Mecum's Classic Tractor Auctions.  Your tractors looked great.
Good Luck!
Bill Long
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 9:54pm
Even the correct police would have to be impressed with that undertaking and making it look as original as possible.  The rest of the tractor has great attention to detail as well!
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 9:54pm
Simply Outstanding!!!! Something to drool over for sure!!!!
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 10:14pm
Andrew, you are setting the bar very high. On here a while ago was a 6080nf and now your 200nf. That is some of the best work I have ever seen. Sounds like you had a lot of engineering to do to make it all come together. Congratulations on a job well done. High marks, top shelf, & A#1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 10:25pm
WOW!! Thank you all for the response! It was a fun project to undertake that is for sure. One of a kind. It is amazing the things that were changed from the 190xt and the 200. Things that you just simply over look! I like the idea of the 220xt!!!! somehow it needs to have a power director installed! As for the mecum auction yes I was on there last November. We sold some of our ac Wheatland's. As for the 200 you will get to see it sell on mecums at the end of the month actually. I consigned it before I actually finished it and now I am really torn! I did at least place a reserve so I am comfortable with it. It is my own personal fund raiser for my wife and I as we have a little one on the way! We are very very excited! Thanks again all!
Andy
Andrew Gubbels
Gubbels Restoration
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 12:14am
Gosh, that thing is beautiful!
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 2:33am
Clean, efficient, organized, functional, what's the word I'm trying to find to describe this beauty you've built.
