hd6B
jlp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlp Quote  Post ReplyReply Direct Link To This Post Topic: hd6B
    Posted: 01 Mar 2016 at 11:40am
I JUST BOUGHT A HD6B SERIAL # HD6B21711 can anyone tell me what year this crawler is?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 12:09pm
approximately middle 1969.  first # produced in 69 was 21432
Edited by CAL(KS) - 01 Mar 2016 at 12:10pm
jlp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 1:15pm
Thanks can you tell me where to look for parts and a service manual? I think it needs steering clutches but not sure would it not turn or not pull if the clutches were bad?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 2:19pm
http://www.minnpar.com has parts manuals online and some parts are still available.  you can also buy service manuals online just do a little searching.  if it wont turn the clutches are probably stuck from sitting or have some issue not releasing them.  if it wont move i would suspect main clutch, as unlikely both steering clutches wont hold.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 4:31pm
I am still have some used parts if I can help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 4:35pm
steering section is similar to HD5 as the rear casting is the same unit - early HD6 were same dry units later went to oil
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 9:37pm
General Gear is where I got a new clutch and pressure plate for my HD5B. They also have steering clutches.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 6:44am
Try running the machine for a while with both steering clutch levers pulled back. Occasionally the clutches will free up. If you decide to put pipe plugs in the clutch compartment drains and flush the clutch compartment with diesel oil, try to clean the debris from the compartment first.
There are a lot of AC manuals and steering clutches on eBay.
jlp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 6:57am
Thanks for the info. Another problem I found is a leak in the fuel tank someone told me that it could be lined any insight on that?
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 7:51am
Depends on how bad the leak is if its just leaking around the seam you can take the tank off steam clean the inside and wash out it with acctone and pour some stuff called red kote in it I have done it on my massey furguson 135 diesel tank . the trick to it is its got to be very clean and you cant let it puddle up in the tank and make sure its completely dry before installing
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 11:28am
Can you post  a picture of it?
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2016 at 10:24am
I have had the liner stuff come off after 10 years,but they claim it is better stuff today. I just got 4inch crack in a D2 tank welded for $40.
jlp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlp Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2016 at 3:13pm
I will post pics of the fuel tank when I get it off now I am searching for decals any idea where to look?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2016 at 5:18pm
JLP can you post pictures of the dozer? we all like to look
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2016 at 8:37pm
I've welded a lot of fuel tanks, more alum. than steel. It's really not that dangerous if you use good sense. Cleaning, and I like to use Dawn dish soap. Take you tank and turn the crack up and fill with water to close to the crack. Solder or weld as you choose. Or clean the  tank, stick a air hose in one of the holes, blow for a bit, weld'er up. You'll need to keep the air going in but regulate it so that it doesn't blow real hard. Been doing it sense back in the 60"S. No blow ups yet.  Leon   Cmo
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 6:50am
I also have welded quite a few tanks.  We would clean tank out, dress cracks and prep then displace air in tank with wire feed gas, weld with wire feed welder(minimize inclusions) and over cover with a good two part epoxy for any possible 'bug holes' in the weld.
Edited by DMiller - 16 Mar 2016 at 6:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2016 at 7:03am
That' good. More than one way to skin the kitty. I guess it's a matter of using what you got. Again, be careful!   Leon Cmo
