1955 rear wheel rotten
theron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote theron Quote  Post ReplyReply Direct Link To This Post Topic: 1955 rear wheel rotten
    Posted: 05 May 2010 at 5:35pm
do i have to use those spin out rims or can i use something else
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 6:49pm
You can get wheels off from some combines that will bolt on but I don't know which ones. Someone on here will.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 8:30pm
Do you have a 1955  WD-45 or a CA ?
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote theron Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 8:34pm
ca
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 8:35pm
In that case combine rims probably will not work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote theron Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 8:35pm
iam sorry new tothis
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 8:49pm
You dont have to if you make something else.  My MM 335 takes the same wheel as a CA.  It had bad rims,  I made some useing Kobota wheel centers and 26" combine rims.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2010 at 3:20pm
Rims off a D-10 (non power shift)  Or a D-12 (power shift) will fit.
Gary
