D12 QUESTION HYD |
Post Reply ![]() |
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3531 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Feb 2016 at 12:34pm |
LATE MODEL SYSTEM - HAS GEAR PUMP
lift arms drift up - can push them down or stop them with about 100#'s pressure. At idle they do not raise. Customer did all the things suggested - spool centered, draft and position backed off,,, Somehow we have system back pressure entering the passage going to lift arms... any ideas? |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5128 |
The traction Booster valve is most likely stuck. It's a common problem with these tractors as the adjustment never get changed enough to keep the valve free, the same for the position control valve. Have someone move both lever and another look up from underneath. The valve plunger should follow behind the linkage.
Edited by PaulB - 29 Feb 2016 at 1:49pm |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54239 |
My D-12 III has the same problem, its in the linkage, if ya try to adjust the TB, something makes it start acting up, so I just leave the TB alone, when using 3 point equip...
Post Reply ![]() |
