silicon or jb weld?
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Topic: silicon or jb weld?
    Posted: 29 Feb 2016 at 6:25am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 6:34am
Whoops! How bout a glass shop? Let them make a window for it. It would be easy then to keep track of the oil level... LOL!
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 6:55am
Yeah,make it smoked glass. At least it will always LOOK full.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 7:00am
I used polycarb on a Briggs once...looked GREAT until I started it, then you couldn't see the action til the oil setttled when shut off. Never leaked in 3+ years !
Jay
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 7:11am
What? Not even gonna give the good old trusted Duct Tape a shot?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 7:34am
hmm..,could screw on some polycarb,didn't think about duct tape ed,that might work! its well ventilated got a bit smaller hole on the other side. It was a cheap motor(free),so I can splash out on some duct tape.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 7:39am
gits the camo duct tape, so it'll hide it better!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 5:58pm
Cows with fistulas die, too...
Orange Tractors View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Tractors Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 1:18am
That is going to take a lot of bubble gum to fix.
Aus D19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aus D19 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 5:51am
N6 engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 7:16am
Yes aus d19,came out of n6, the guy who owns the n6 took it out and put a 8.3 cummins in instead. He had only just rebuilt this one so the liners and pistons should be still good (bar the one the rod hit,) turbo is near new as well.   Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 8:14am
spose Case 2290 engine wouldn't work eh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 9:01am
how's zat happen on a fresh engine?
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 10:29am
Well if you manage to save that block make sure you take alot of photos we will all want to see how you repair it. You will be the master of motor repairs when you are done. I think it might be time to head to the scrap yard and see if they have nicer donner motor. Oh wait that is what the first owner already did.... wow that looks expensive for a rebuilt motor would be interesting to know what went wrong so we don't make that mistake.
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 10:41am
Just drill holes along all the edges where it split and "stitch" it back together with zip ties; just make sure they are the heavy duty ones. Cover with duct tape to seal the oil. Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 10:50am
Good idea make sure they are the black up rated zip ties.   Wouldn't want to have to redo it in a few years because the sun got the best of it...
cmsmoke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 4:29pm
That will buff out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 4:30pm
Conrod broke in half, bottom is still bolted to the crank. I rememeber when it happened that he rebuilt the engine because aircon compressor belt came off and took the fan belts off as well and the motor got cooked. Now after all the years ive been on here i,ve learnt sheding belts is abad harmonic balancer ,,so maybe it started the saga ,why a rod would break in half though, youd think it hydralocked for that.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 11:15pm
Maybe they should use Buda rods......  This one bent almost 90 degrees and no signs of fracture.
PatrickBeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PatrickBeth Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 5:15am
It's perfect the way it is, don't you watch those picker shows? Don't touch it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aus D19 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 6:01am
Ours broke at the piston pin bush.guessed it was the piston pin bush failed,our engine had about 1000 hours on it.Pistons 5&6 had valve inprints on them, as cam gets broken when the rod vents the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 6:21am
OR, the cam broke causing the valves to hit piston, breaking the rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 6:31am
That bent rod gives a new meaning to "stroker engine"...
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 8:29am
I had that happen ona combine engine about 2 hours after an oil and filter change. was on the last 1/2 round of being done with harvest!
