WD axle bearing
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: WD axle bearing
    Posted: 25 Feb 2016 at 12:32pm
I need to replace the top outer bearing on the axle shaft. Can this be done without removing the shaft?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2016 at 12:56pm
Do you mean the outer pinion shaft bearing? If that is the one you are referring to, it could be replaced, if you can get the race out and then pull the bearing. I don't know how much room there is to work in there.
 The outer axle bearing is between the Hub on the axle and the final drive bull gear and the pan and axle would have to come out to replace it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2016 at 1:05pm
Yes sir you are correct. I might was well pull the whole thing off since I already have the brakes out of it.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2016 at 1:31pm
The hard part is done.
