720 differential seal
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: 720 differential seal
    Posted: 22 Feb 2016 at 1:45pm
I took the brakes apart to clean them and so I could paint the frame rails and final drives, and noticed the seal had been leaking and plugged the weep hole. I ordered 2 seals and orings to replace them before I put it all back together. Is there anything I should know on replacing the seals? Didn't want anything to fall down inside the differential. Already pulled the shaft out on one side but the simplicity manual showed that. Wasn't sure of the purpose on the snap ring on the shaft either.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2016 at 5:48pm
do you have part numbers for yuor seals and possibly brake shoes i need to do brakes on mine some time this year    but i do not know the answer to your question   sure some one will chime in
