I am getting power steering fluid in dist points, |
boscoe
Topic: I am getting power steering fluid in dist points,Posted: 04 May 2010 at 6:57pm |
D17 gas 226 , i am getting power steering fluid, I actually use auto transmission fluid in ps, in the distrubutor where the points and condenser etc. , are located I dont know what the problem is and not sure how to fix. The tractor stalled on me this morning and when I took of rotor cap and cover there was a good amount of oil in the dist chamber, is there a seal or gasket that can be replaced or what I was thinking is that the breather is plugged on the ps to create pressure I dont know. If any one knows please let me know what you think . thanks,
Albert
Posted: 04 May 2010 at 10:09pm |
There is a seal at the rear of the pump that sounds like is leaking
Dean Ag 800-589-2426
Rick
Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
Posted: 05 May 2010 at 5:19am |
Albert is right...the seal in the pump is leaking and needs to be replaced. Rick
DrAllis
Posted: 05 May 2010 at 6:17am |
The seal is leaking and possibly the needle bearing inside the pump are also worn/worn out. Why don't you change the oil and get rid of that %$#@ water like transmission fluid and use universal modern hydraulic fluid which is thicker.
boscoe
Posted: 05 May 2010 at 7:12am |
I can use reg hydraulic fluid in the power steering? ok I will drain the auto transmission fluid ( it really is thin stuff I agree) and replace, albert I will call you today you maybe have the part I need? thanks all.
Creek Jenkins
Joined: 14 Sep 2009 Location: Northern Minn Points: 812 |
Posted: 05 May 2010 at 10:14am |
Or you can just take the whole ps setup off and give it to me!
(my birthday is coming soon, not many shopping days left...)
Creek
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 05 May 2010 at 11:47am |
DR, I'm glad I saw this post. Am I correct in thinking that it just works better with hytran in it? Got my pedestal off and fixing leaks/bearings at the moment.
DrAllis
Posted: 05 May 2010 at 4:11pm |
Just use the modern day hydraulic oil....everything works better and far fewer leaks.
